The Gabriel Device, possible COP=8
Started by Feynman, March 22, 2011, 04:07:09 PM
Mavendex
Permalloy is 80% nickle and 20% iron with a little yum yum in there, I would think it would be fairly simple to work.
Question to all the really smart guys out there, please keep in mind Im not a super scientist or a Electrical engineer, Im just a tinkerer and trying to make this place better.
Heres the question, Powerfactor if on the input of the transformer you have 0 power factor and you are still powering a load on your secondary side no matter how much energy your useing on the primary everything that your useing returns to the source right?
IE if you have 120 volts x 20 Amps x 0 pf you are actually useing 0 watts cause everything goes back to what ever your drawing off of, then your secondary is powering 500 watts that would be 500 watts of free energy am I correct?
Or is it that simple.
Quote from: Mavendex on August 07, 2011, 04:06:30 PM
Correct. If there's truly no coupling as is mentioned here then the only power draw limit would be the materials that are used although I still have no idea how or why this transformer does what it does.
CLaNZeR
If you had no load on the secondary, you are still powering the primary.
So the energy will go to heat down to Joule Heating, so you will still be using energy to put power throught that coil.
http://www.overunity.org.uk
Mavendex
Can't we just keep a constant load on the device and utilize the free source, IE sterling engine, capacitors, heater, multiple heaters, battery charger, ... then the Transformer/Device would then return all the energy used and we store the stuff that was created?
Or put a switch on the primary input?
CLaNZeR
Quote from: Mavendex on August 07, 2011, 06:48:49 PM
I think your next goal is to close the loop.
If you have got more energy out than you are putting in, then put a middle man storage device in place such as a big Cap. Jump start the Primary to get it going. Loop the secondary to the Cap and when it is at full charge feed this back to the primary and cut the main supply.
Then monitor power and see how long it lasts, if it keeps going then start adding a extra load to the secondary and build it up till you have pulled what you can without stopping the loop.
With any coil/inductor such as your Primary when pulsing, we get nearly all the power back when we cut the power. This comes back in the form of the back spike or BEMF. The rest of the energy losses get swallowed up with heat and a few other factors.
Hence why we so many claims of rotor vonfigs self charging from bemf spikes.
