The Gabriel Device, possible COP=8
Started by Feynman, March 22, 2011, 04:07:09 PM
Hope
I will try a pvc ring separating the two bar halves and be careful as to tuning on the center zero point (if there is one).  According to Walter Russell's drawings there are expansive electricity and contracting electricity and they can cancel each other.  So I will try to keep the barrier intact between them.
The mold of the toroidal I suggested is large and we can make the inner core like you wish then mold the outer core in two half's separate electrically and join them insulated from each other, wind them and see what the large but close primary will give to the secondary with tolerances much closer.  This molded primary core should be a lot better than 14 gauge steel if we select the mixture properly.   What do you all think about the CordPro as a mold (they also make one twice as large and a smaller one also)
TEKTRON
Quote from: Hope on August 15, 2011, 12:31:48 AM
Touching on a variant using old Ed L's magnetics theories.  Has anyone placed a chain within the path of a Rodin Coil vortex (through the center) to see if has discoupled magnetic fields that can be collected thru coils wrapped on the or a link of the chain?  Granted this chain may have to be insulated to keep it from bumping into the vortex center wires and perhaps bending them or causing damage.     BTY this island I live on is surrounded by beaches with black sand available for the collecting.
Hope, Is your black beach sand magnetic?
Hope
Magnetite is found here, so I can find some and make powdered magnetite.
I live on Whidbey Island in the Puget Sound.
Hope
I am showing some ideas how the real full picture how expanding and contracting currents work.  We are only taught about expanding currents which are marked by heat collecting.  BUT there is a second part which we must learn to use as well.  I know these ideas are incomplete and ruff but I want others here to see them anyways, so as to explain some now hidden working of matter.
Hope
More pics
Iron has LOTS of carbon so is a great attractor of most types of magnets (charge amount and frequency).
