The Gabriel Device, possible COP=8
Started by Feynman, March 22, 2011, 04:07:09 PM
CLaNZeR
Just a quick post amongst my manic life !!
Got the inner core all wound up and happy with the resistance.
Now just waiting for the shell to arrive!
Cheers
Sean.
http://www.overunity.org.uk
JouleSeeker
Awesome, Sean!  Pls keep us up on your progress -- and more POWER to you!
  Question --is the Gabriel device related to the Bi-Toroid Transformer? (BTT)   See attached diagram.
There is the inner toroid (permalloy) and the outer shell which is also a toroid...  in the Gabriel device.
My reasoning is that the primary in the Gabriel case sees TWO toroids, whereas the 2-ary sees just one toroid, the inner one.
Follow-on question -- can the Gabriel be re-designed as an equivalent BTT, with the "II" in the diagram becoming the primary and the "I" becoming the secondary?  Has anyone tried this?
--StevenEJones
Magluvin
This would be closer to the Gabriel device, the thin "shell" I added to the left core.  ;]
Mags
SchubertReijiMaigo
Hello, some news about the replication:
Yesterday, the shield was cut, and today starting experiment, my version is like the first Gabriel device presented in this topic:
The outer shell is cold rolled steel, and inner is nanoperm (u=30000)
Primary is with at choice: 15/70/120/150turns for 12V 50Hz...
Secondary is 117 turns...
I have tested different configuration and obtained strange result, like input current decreasing when I load secondary, but if I overload the input current goes up...
Just a bad thing I was not able to reproduce like the Mav version: The toaster at primary goes down but light at secondary is full brilliance...
More test still needed and I plan to buy True RMS watts meter because measuring with light bulbs is not very accurate (you don't see if input is reactive or working current)...
But it seems the output current depend directly of the input current...
Bad thing: When I feed the device with the inner coil, I have some EMF transfer, but the inner is saturated (B=1.41 Teslas) so I will test with amplifier at higher frequency to avoid saturation...
Mavendex
insulate your shell halves, wind it down to 0pf
