The Gabriel Device, possible COP=8
Started by Feynman, March 22, 2011, 04:07:09 PM
Mavendex
Quote from: SchubertReijiMaigo on August 23, 2011, 03:34:05 PM
@ Mags: Yeah I know this, I have read decade of times this patent LOL, I have the constant current at all load phenomena, now the deal is to test the two theories: The FE is when I have more and more voltage by winding turns at secondary, for example 12V 1 amp input 120Volts 1 amp output, or the phase difference, at 90° no matter load the input current will remain same (the BEMF help entirely the primary instead fighting...)
@ Mav: 120 years until someone reinvented something similar and test it, he he !
@ Broli, sorry I don't understand how to measure accurately the power with a DSO, I 'am not skilled at this, but investigate to buy the cheap DSO in the link above...
Hope
Please write this up as far as specs, build instructions and parts list of at least one working model.  Include the principles as found.  I have done technical writing for a major manufacture of electronics/mechanical equipment and would help if you wish.  We can place this document in the downloads area so as to make it easy to get it to members who will build theirs.  Thank you.
Is this your wish?
Is this for us all?
Richard
Hope
Quote from: SchubertReijiMaigo on August 23, 2011, 10:59:31 AM
RE:
It look like I have some good news...
Test was with amplifier, at 24 Volts input.
Observation:
1) It seems the output power depend directly of the input current...
2) The secondary current seems to be constant at all load...
3) The best result was when I don't saturate the inner, (inner was at more or less 1 Tesla)...
4) Two test was made: one with 100 Hz and another with 250 Hz...
5) At 100 Hz the output the bulb more brighter than input bulb.
6) At 250 Hz the input bulb was off but the output was gloomy.
7) If I up frequency the output become darker.
8 ) It seems to have an asymmetric, unproportional current between input and output...
9) Traditional transformer windings ratio doesn't work here, 12V 100 turns will not turns into 24V 200 turns for example !!!
Hypothesis:
1) I think is better to not saturate the inner.
2) To increase output with no input, I think to wind more turns at secondary OR
3) The FE effect is not related to Heins effect but rather a phase difference between primary and secondary, more the shell is thick more you have phase difference, at 90° you can put any load you want the input will remain zero..
4) OR both phenomena described above...
Now Photos !!!
Your message sheds light on Walter Russell's note that gravity was at a 90 degree opposition to current flow.  FINALLY!!!
SchubertReijiMaigo
If anyone is interested to make independent verification and for backup data about this experiment:
I post the exp. data I use here:
1) Take a Nanoperm Magnetec toroid a M116 one (u=30000).
2) Take a cold rolled steel shell at
http://shop.ebay.com/i.html?_kw=steel&_kw=donut
the 7.5'' outer / 2.5'' inner version, vendor was:   eworldsales1
3) Cut it in two half properly, avoid the gap between them, drill two small hole (2.5mm) for the wire secondary can pass through the outer shell.
4) Isolate the two half to avoid Eddy. (Eddy will create losses, make it less efficient and overheat the shell (single shorted turn effect)...
5) Wind secondary, mine was 117 turns exactly...
6) Put this secondary into the two half, put the wire in the two hole, and close it, no gap should be here (I wonder if the gap is important or no ?).
7) Start to wind primary, mine was with several input:
    Winding A: 70
    Winding B: 25
    Winding C: 25
    Winding D: 21
    Winding E: 15
For a total of 156 turns. My test was at this number, Boucherot formula will give me around 1 Tesla magnetisation (including shell )...
8 ) Input was 12 VAC 50 Hz, or 24 VAC with amplifier and frequency generator.
9) The load and input bulb was car headlight bulb, 12 Volts with two filament 40 watts and 45 watts, use only one filament and the same for both bulbs, in my test it was the horizontal filament...
10) Input bulb is on series with primary, load is at secondary...
11) Play with the device, (frequency, voltage, turns) you should observe non linear characteristic and disproportional input/output current...
12) For improving output: two theories at this time:
      A) Increase number of turns at secondary.
      b) Increase phase difference by a thicker shell (need to build another   device with a new shell...)
      C) Both phenomena...
13) Enjoy !!!       SchubertReijiMaigo 08/24/2011.
Hope
What would be a metglas equivalent part number, these are rated at 1.56 tesalas? I mean which part number would best fit which steel doughnut?
