The Gabriel Device, possible COP=8
Started by Feynman, March 22, 2011, 04:07:09 PM
SchubertReijiMaigo
@ Broli: Something like a gaped inner core, will give you low µ, low µ will be hard to magnetise and draw a lot of reactive current but I wonder if the secondary will be able to produce more power since it's hard also for BEMF to magnetize...
Actually with this device it's his poor weight/power ratio: 5kg of metal copper for a decade of watts is not too much !!!
Gasoline power density is about 3000 Watts per kilo !!!
Quote from: SchubertReijiMaigo on August 27, 2011, 05:59:10 PM
I wouldn't worry about the high reactive current, this can be eliminated by a resonant capacitor, only need to make sure it can handle the voltage.
Hope
I finally found a supplier of nano mag powder all!!
http://xuzhounano.en.made-in-china.com/product/aqxQtgPbaScF/China-Nano-Magnetic-Cobalt-Powder-27NP-HW-.html
if we want to make our own cores  this maybe the correct powder, (I believe it is worth a try)
This is the wire and winding specs.  On this site is also a great terminology section.
http://www.mhw-intl.com/assets/CSC/CSC%20Wire%20and%20Winding%20Data%202011.pdf
Hope
Just a couple of thoughts that I woke up to. The Rodin coil is thought to be following the natural path of flow and is > 60 % more efficient.  It might be found we should connect the ends of it (maybe with a capacitor) so it is complete and learn to energize it at different point(s) (perhaps at the different number points used to create it’s geometry ).  Maybe we can create a 90 degree phase shift just using a Rodin coil and have the Gabriel effect duplicated by this one coil.  If we make the primary out of a Rodin can't the secondary capture all of it since the Rodin's wire can be non ferrous?
And if a Rodin coil is so efficient at making a magnetic field, maybe it is also good at capturing a magnetic field.  If so it could be that it is useful at capturing the Gabriel devices magnetic field or could be useful in this project somehow elsewhere?   Good night friends.
Mavendex
Think less rodin coil, Think more Vortex windings
