The Gabriel Device, possible COP=8
Started by Feynman, March 22, 2011, 04:07:09 PM
JouleSeeker
Hope:  Will this company in China sell small quantities to individuals?
@Mav:
QuoteSo far Ive smoked a couple of them, it won't take over 180 volts, and it won't take over 20 amps and starts beeping at you once you hit the threshold of 15 amps input/output. I use a Fluke Amp clamp/volt meter if expect to take voltages over 180 and then use a low load to determine amps like a 2.5 amp halogen will burn brightly at 120 v and 2.5 amps if your over on volts then you know your amp pool is full and then take a voltage reading, I wouldn't take those guys over 190 tho they burn out :)
Seems pretty reliable my variac has a separate analog meter attached and the volts reading on the killowatt match the analog meter, if your using 15 amps you will know it cause of the sound it creates, and she keeps up pretty good.
I got two new configurations going on at the moment Simultaneous to speed things along, 1 configuration is 750 feet of 9 gauge wire on the secondary which is a M-117 core, and haven't yet determined my input gauge yet that will be tonight's test, I'm expecting to support 120 volts and plenty of amps with that and should take us over, after the mass experiment.
Thanks for this input.  I take it that the kill-o-watts will work at <120 V input, please correct me if I misunderstood ...
And that 15or 20 amps is the maximum.
Best wishes on your tests.  I'm not there yet, but hoping to learn also how best to amplify the power in....  Any clues from your experiments and tests would be appreciated!
Magluvin
Quote from: Hope on August 30, 2011, 05:08:53 PM
Here is the link for nano powder from the page 48
http://xuzhounano.en.made-in-china.com/product/aqxQtgPbaScF/China-Nano-Magnetic-Cobalt-Powder-27NP-HW-.html
Hey Hope
Is this the best stuff?   I wonder how Neodymium material would work as a core. not magnetized of course . Or is Mavs material find better?  If I go this route, I want zee bezt. ;]
Max flux density.
Im still going for 1/2 in dia inner core at 2 in, long.
Im cutting enough wires to fill the void and as the jb takes up some space, Ill have a few left out Im sure.  Pretty much a rubber gloves job until I figure a solid method or go nano, or other particle/powder mix.
I would think that a powder with resin, to get a dense powder mix, the result before hardening should be a consistency of clay?   This interests me. Nano Goo Cores.
Maybe if thin shell containers could be used and we can fill the shell container with the powder, which could be made into a nano fluid with oil, then the material can be reused for something else if the subsequent cores are not desirable any longer. This would be good if the materials are expensive. Especially during development.
Ya know, I find some toroid cores that if you scrape the coating off, they are just iron, or what ever composition, but they measure continuity all over. Wouldnt that be a huge loss?  Maybe they are for chokes, but losses are losses. A choke is just suppose to impede, not consume the unwanted.  I always scrape them to test for this with unknown cores.
Ok, time to put on the rubber gloves.  ;]   After cutting many many wires. and paint.  ugh.  ;]
Mags
Cheap4All
Quote from: Magluvin on August 30, 2011, 08:07:25 PMI find some toroid cores that if you sc the coating off, they are just iron, or what ever composition
Nanoperm is very thin strips of iron which after being molten and then formed is cooled superfast giving it a different crystalline structure, and thus improved magnetic properties.
Be careful with powders, as is they probably don't have a high permeability unless you compress them under high pressure into shape.
SchubertReijiMaigo
QuoteThanks for this input.  I take it that the kill-o-watts will work at <120 V input, please correct me if I misunderstood ...
Beware with this, this kind of cheap meter don't measure deformed current (saturated trafos) switched power power supply) it's designed to work at or nearly 120 volts and 50 or 60 Hertz...
It's not a true wattmeter, Beware of false value !!!
