The Gabriel Device, possible COP=8
Started by Feynman, March 22, 2011, 04:07:09 PM
0 Members and 23 Guests are viewing this topic.
Hope
Also every working aether device I have seen on the net seems to have an antenna of some type to gather quickly the aether charge.  Is this not needed with this device?  Even the renown Nicolas Tesla needed them on his device. When the coil shorting expert works his magic he too uses an antenna and he is using a sort of phasing of his fields by shorting quickly the fields and his device is a now days working unit.  Why isn't it necessary for us to use one?
Mavendex
AmericanMan31
 HOPE     ...
     Whos to say the secondary coil isnt an antenna, I mean ..it certainly is picking up aether-like energy in an unknown fashion, right? Antenna!--viola.
Mavendex
I didn't want to be the first one to say it but what if its all condensed in to one deal antenna generator vortex, just a thought...
Hope
I can see that as an antenna.  But lets make a surface plane antenna not within a isolated metal doughnut and feed the secondary it's bounce back needs with it so the path of least resistance is enhanced to see if we can make 8X into the next multiple.   Lots of devices seem to hit 8X and those that go on to the higher increases have an antenna outside the device.
Mav, I know this is important and also it seems like it sidelines the gabby a bit but in the long run this idea will be of benefit to lots of devices once we Gok the true principles making this unit work.  Science now knows main vortexes have small mini vortexes all over them which correspond to harmonics,  the elements are bound to harmonics so why not figure a way to include this knowledge to an advantage?
Also, to you all, I am negotiating with a company in China to get far better pricing on nano crystalline cores and will have more news as they make an offer tomorrow (I hope).  I want to place two cores at 90 degree angles in the primary and secondaries which should reveal if vortexes can be modified and a gain can be modulated and captured.  It is like phasing but with physics + HV.  Perhaps just placing a spark plug in the center of a nano cry. core would make energy generate then be captured in the ultra core covered by a doughnut BUT the secondary could have a winding that is FED by an antenna outside the shell.  You have a core you can check this with?  I am waiting on my core purchase until I get an answer from China.(they have USA distributors already)
Its been a long day and i have  worked hard so good night you all.
