The Gabriel Device, possible COP=8
Started by Feynman, March 22, 2011, 04:07:09 PM
SchubertReijiMaigo
Hello everyone, just a short news about scope:
1) Test was made with the same version described at page 43 of this topic and download section...
2) First observation: the shell  is like a phase lock: at no load the PF is 0 with distorted sine wave (shell saturation)...
3) When I put the light bulb the PF goes up to nearly one (but still some power returning to the source).
4) Idem with more load or shortcircuit (in shortcircuit the PF tend to decrease !!!)
5) Voltage are in phase both in primary and secondary !!!
6) Current are in phase both in primary and secondary also !!!
7) Like Tesla said, the shield protect a phase difference between Voltage and current at input side...
8 ) Maybe increasing the shield to the equal surface of the inner core will result a full phase difference of 90° (PF=0 at all load)...
9) Scope shot with the 40 watts bulb secondary load: The green curve is input voltage, the yellow one is current (voltage through a shunt), the red curve is power (Green*Yellow) beware the zero line is at the "M" label at the bottom left of the screen... You will see a very small portion returning to the source...
matthewklinko
Quote from: SchubertReijiMaigo on October 23, 2011, 05:09:14 AM
Thanks for your results they are pretty much the same as what I get
Power factor at no load is zero
I can phase delay the secondary voltage by 90 degrees if you increase frequency to about 2khz on no load.
But as you load Pf goes to almost 1
Shorting does reduce power factor by a small amount as you said
Hope
Seems I was in error Mavendex, I must of had a brain fart.  Wasn't intentional, just to many irons in the fire here and fatigue takes its toll.
I updated the Gabriel Device in the downloads section.
Acquired a ancient 45 amp / 0 to 135 volts Variac and need some recommends on a frequency generator.  Funds are limited just now but I am searching for needed materials for a build.   Received a good deal on a couple HV trafcos this week on the mainland.
JouleSeeker
Quote from: Mavendex on October 21, 2011, 09:01:36 AM
Im back but busy catching up on work, I meet with investors on Monday, after which I do a little show for them and we talk about where we should get started.
Hi, Mav!  This is Dr. Steven Jones.  While I strongly support your work -- and understand the approach of involving investors, at the same time here is something to think about, from a thread I started over at OUR.com, post by wattsup:
QuoteRegardless of the build grade Level, inventors should realize that weather they go public or try to hold it under their belts for patenting and commercial routes, they should not get overly invested because regardless of the final disclosure method, give it 3-6 months and that first disclosure will be rendered obsolete. So for any OU inventor, the ultimate payback will be eventual obsolescence which is the natural law of exponential progress and if you cannot know this in advance, then you will be investing important monies in your own demise because someone will come after you and their derivative technology will make yours seem like the stone age very quickly.
wattsup
I urge you to think carefully about this...  You are welcome to join the discussion, get feedback
here:
http://www.overunityresearch.com/index.php?topic=1160.msg17868;topicseen#msg17868
Mavendex
Thanks Doc.
Both my friend and I are into this to save the planet not make richs, Teslas construction with the modifications I have listed plus a few electrical components that were not available in Teslas day will make it so we don't have to rely on the fossil fuels any longer.
Thank you for your support, and we will keep things as humble as possible. Although doing research for a living would be a nice turn of events vs. working 40 hours for a job then dropping another 40 into research and development.
Money is nice to be able to make cash from farming energy would be excellent. but all in all I would just like to see oil used for something useful instead of feeding our gas tanks.
