The Gabriel Device, possible COP=8
Started by Feynman, March 22, 2011, 04:07:09 PM
Magluvin
Hey Mav
Are you saying that you have wound shorted turns, on top of the sec, and are not electrically associated with the sec? Any leads out of the shell to measure current in the shorted winding?
Like, just some shorted loops, or a complete other winding that is shorted? Same no. of turns and size as sec?
Also, do you think the heat is from the shorted winding, or a combo of it and sec?
If so, then maybe more smaller(less turns) windings with heavy loads. Be interesting to see a big ac induction motor driven with little input.  ;]
Good work dude.  ;]
This all makes me think of how Tesla got that big ole 80 hp ac induction motor(300 pounds if I remember correctly) to power the Peirce Arrow without batteries.
Maybe he used some of these ideas and he built into the motor. Modified.    ;]  I wouldnt doubt that Tesla would have taken advantage in all parts of his circuit.  ;]
Thanks Mav, for everything.  ;]
Mags
Mavendex
Quote from: Magluvin on October 25, 2011, 10:33:59 PM
Hey Mav
Yes and the one time I did have a loop on the outside to measure the current in the wire, the wire read 7 amps with the input being 10 amps.
Not the same number of turns, too many shorted turns yields less and less voltage out. But Think ultracapacitors on the shorted ends that will be interesting
Heat is most likely from the shorted turns my tape is rated for 200 degrees and it basically disintegrated while my electrical tape around the secondary was not as badly corrupted
Good work dude.  ;]
Theres more to come when we hit 88 mph your gonna see some serious shit  8)
Mav
matthewklinko
Quote from: Mavendex on October 26, 2011, 09:17:13 AM
Hello Mav
7 amps on the shorted turns that's a lot of wasted heat ! I really dont understand how it's any benefit . And when you say it stops reflections do you mean that the input always stays at 10amps and pf of 0, when the secondary is loaded and not loaded .
To help understand , can you give an example where shorted turns has given you the best result.
What was the power in and PF, and power out on no load
And what was the powerin and PF, and power out with load and what type of load
Thanks
Mavendex
Quote from: matthewklinko on October 26, 2011, 03:51:15 PM
Hello Mav
ummm that was one experiment if you read that properly I have done this several times now.
0 reflections
Nope nor will I give you my latest construction
Thanks
Your welcome
matthewklinko
Quote from: Mavendex on October 26, 2011, 04:36:10 PM
haha ok Mav, well thanks a lot for your help so far.
I have just bought myself a 240V 25A variac so I will continue my testing :)
