The Gabriel Device, possible COP=8
Started by Feynman, March 22, 2011, 04:07:09 PM
matthewklinko
Hello I had a play around with the variac.
I have the same setup 2000 turn secondary , and 400 turn primary
I had to input about 90v peak AC, before the core would saturate.
The more you increase voltage after that point the more current will flow.
I set the current to about 2 A and loaded the secondary and the current goes down. You can keep loading the secondary until the all the excess flux is used up (core stops saturating), after that point current starts to rise.
You can't drive the current down more then you are using, so min current is still magnistising current + load current
SchubertReijiMaigo
I can confirm this with mine...
QuoteYou can't drive the current down more then you are using, so min current is still magnetising current + load current
Yeah , the good: current decrease upon loading, the bad: you can't not extract more if not current rising again, and the ugly: the load current is PF=1 fully reflected to source...
matthewklinko
Quote from: Mavendex on October 26, 2011, 04:36:10 PM
Hello Mav
SchubertReijiMaigo and I , have tried building your first build. (Core, Secondary, Shield, and primary)
We both can't get your observed affects, I believe your first build didnt have any shorted turns. Can you give us
any advice we are missing.
I have used a power meter, variac, and oscilloscope , and cant get a power factor of 0, or getting more current out then in.
Mavendex
Unless your using tin-plated twisted pair copper wire for your primary, This rather large shell and the same core your not doing the first build your doing your modification which your having trouble with and want help for which I gave you a fix IE shorted turns.
