The Gabriel Device, possible COP=8
Started by Feynman, March 22, 2011, 04:07:09 PM
MenofFather
Quote from: importfanatik on April 29, 2011, 09:58:11 AM
Well,. I gave it a shot,. but had no luck at all.
But it should be noted that I didnt use a nanoperm core, and the scale is smaller, so its not a true replication and can't really validate if Mav's claims are true or false.
Here is what I built:
Toroid Core: Ferrite ( i think)
Outer Shell: mild steel, 4.5" OD, 1.5" ID
Outer shell halves are insulated with electrical tape.
Primary 80 turns clockwise
Secondary 304 turns clockwise
Power: 12V car battery -> 60 watt inverter -> "gabriel" transformer in series with 60watt light bulb.
Secondary shows 12VAC ( i had to remove alot of turns from the primary to get it UP to 12V)
Used 4 diodes (bridge rectifier) to get that to what I expected to be 12V DC.
According to the multimeter it is 5.4V DC (weird,. i must have done something wrong).
Tried to run that to a car headlight but no luck,. maybe because the voltage isnt right,.
Oh well,.. was a fun experiment in any case and I learned a little about electricity.
Edit: I forgot to mention, primary and secondary are both 18ga magnet wire
If you use 220 volts, for primary need more turns, expeshaly if you use smaller steel ring and not 120 volts but 220 volts. You need about 400-600 turns, not 80 for 220 volts. For 120 volts about 200-300 turns.
forelle
Hi to all
i read the whole thread yesterday and my question is why the discussion stoped.Has nobody else than Mavendex the device running?Has somebody made it running for 220V?
Thanks
Feynman
Why did development on this tech stop?
the_big_m_in_ok
Quote from: Feynman on February 18, 2014, 09:10:53 PM
In response to this posted reply and the one immediately previous to it...?
I'm on a small, fixed income while living in San Francisco (read: expensive; high standard of living).   But I did have the inspiration of taking the output coil and have the leads of it wired to another complete Gabriel Machine stage after it the amplify the output of the first stage.
       (All theoretical at this point in time, of course.)
What I can do inexpensively right now is take a large cast iron nut from a street lamp that fell off into the gutter, and then use a smaller paper tube 'toroid' inside it for for the output stage.   Winding the coils may take some time, but I have these parts now---or I should have them.
Questions?   Comments?
--Lee
BTW...
Others may have their own opinions why research ended on this thread.   Are they out there to give their opinions for us to read?
Real Boots
Feyman:
I am wondering exactly the same thing, I have read the entire thread and looks like Mav disappeared before posting any results on the silicone steel core construction which to me is the modern equivalent of the Tesla patent.  Any news or updates on this one from anyone is appreciated as I personally will be trying to replicate the Tesla equivalent of this with modern materials myself to try and verify the phase shift which to me is the equivalent of OU as all the inductive energy can be recovered with DC Pulsed operation very easily with a simple diode.  Anybody other than Mav actually manage to achieve the phase shift in secondary current vs primary as per Mav 's posts and the tesla patent?
