mrwayne
Correct, by itself - as presented "is not" super effecient, which I why I authorized that part of the machine to be released.
Even last year I was trying to explain that - yet the desire from all was to jump to the end.
You see how hard it was to understand at first - and the rest of the system is mind boggling - if you do not understand the "Travis effect" I do not wish to present gibberish - which is what I would sound like with that effect misunderstood.
It is the key that had to be understood to build a device to harvest net energy from buoyancy.
And you see how such a simple thing can be overlooked.
Peace and blessings
johnny874
neptune
in a closed system a staic head will 2psi of force, tne same static head open to tne atmosphere will have 14psi,
tnis is somethinb engineers know.
bolt
Regardless if the system can be made OU is not the point. Fact remains the COST per WATT is extremely expensive, not for DIY solution and therefore cannot even compete with a 100w solar panel or small windmill.
This project is probably only ever going to make a museum item regardless if it works or not. There are far better alternatives.
mrwayne
Really?
Is this just a bait comment - question, come on....... you conclude that how?
Ok, I will bite -
We initally come in costing the same as Solar PV for a comparable wattage - unless you remember that solar works 6 hours a day at its peak ability.......
We are partnering with Solar PV manufacturers - for obvious mutual benifits.
"This is why the "Third Party" evalaution has stated - this will replace both Solar PV and Wind alternative energy".
It will aslo increase the Demand for Alternatives since the Return On the Investment is better than Fossil Fuel - a first for alternative energy.
Hope that helps,
Wayne
Wayne:
QuoteIt will aslo increase the Demand for Alternatives since the Return On the Investment is better than Fossil Fuel
I am pretty sure that all of us would like to see your ROI calculations.  Can you share them with us?
