johnny874
   @All,
  Just watched a show on the Science channel called How Do They Do It ?
They had hovercratfs on it. And on this one hovercraft which could hover 3 feet above the ground, could have a man working under it with a hatch open because the air pressure was so low. How low was it ? One claim was it could run over a land mine. To demonstrate this,
they had it run over an egg. The egg didn't crack.
By now, you're probably wondering, how much does this hovercraft weigh ? It comes in at
a light 20 tons. It's also 65 feet long and, hmmm, maybe you'd prefer to read a little something about it for yourself ?
ttp://www.thinkdefence.co.uk/2010/05/fdr-littoral-2/
I guess it's about air compression.
        Jim
johnny874
   @Wayne,
I think this is the answer you came here to find.
Myself, I like posting with people like MoRo, Webby1 and Raphael Ti, they are my kind of people.
With the picture, the cap can be lifted by the opposing cyclinder dropping. It does not use the Travis Effect but uses principles in hydraulic Theory. Since you are a religious sort, my gift if God gave me one is not engineering. i have worked hard to elarn it and understand it. A gift is something that comes easily.
With the picture, the 20 psi area can move away from the cap. If so, even the 10 psi area can do so as well but more slowly. In a fixed concept, as the 20 psi area expands, it will seek equilibrium with the 10 psi area. Even Jesus said there must be balance in all things but doubt he was refering to engineering.
As the 2 areas seek equilibrium, the piston in the floor of the assembly is moved downward with 10 psi acting upon it's surface. If the primary (large) piston has 3 times the surface area of the piston in the cyclinder beneath it, that would result in 30 psi of hydraulic not pneumatic pressure. Hydraulics is not compressible and would lift the opposing cap a height equal to it's movement. It would be this lift that would reduce it's 20 psi area to something lower, even 10 psi which would allow for a greater chance of operation.
If it can not be demonstrated mechanically in one direction, it would not be worth pursuing further. The components are all capable of being tested independently and as an assembly.
Something any engineer should be knowledgeable of and understand.
The basic reason it could work ? The hydraulic pressure which helps to change the primary motive pressures comes as a result of waste energy.
And if this works Wayne, don't thank me.
        Jim
p.s. the Travis Effect would only help in moving the low pressure (10 psi) chamber lower. It's the hydraulic cap at the bottom which everyone has ignored  :o
mrwayne
" @Wayne,
Myself, I like posting with people like MoRo, Webby1 and Raphael Ti, they are my kind of people."
        Jim
Hello Jim,
I like'm also.
Sorry, lost in translation, I can not tell what you are showing, what are the functions of the picture - cap - 20 psi, 10 psi? It looks like the assembly moves as one piece - down.
Thanks Wayne
Wayne
Wayne:
I challenged you with this:
You show me where I am "attacking" and "slandering" you.  Go ahead, quote what you think is relevant and I will respond.
You claim you have third-party verification.  Do you have some links?   If you are just making this claim yourself then it is meaningless.  The test report has to come from the third party themselves.
You ignored what I said.  So please no more whining.
Looking forward to something substantive showing that you have something.
Also, if you really have something, why don't you simply open-source it right now for the benefit of all mankind?  Surely that's more important than your pocketbook.
How come whenever an inventor claims that he or she has something that will completely transform the world and end wars and hunger and usher in the Age of Aquarius....  It's always a "big secret?"
Why is that?
mrwayne
"I challenged you with this:"
Milehigh,
You double down.....
I wait for an apology.
Until then - Good day.
