Wayne,
I am sorry.
I can tell you one thing.  If I had discovered Fire 2.0 I sure as hell would open source it.  Why try to become the "Bill Gates of Buoyancy?"  Why?  Do you really want a mansion with 20 bathrooms?  Wouldn't you prefer to start spreading the word so all of the starving people in the world would have easier access to energy so they could feed themselves and better their lives?
If you open sourced a free energy buoyancy device that ultimately saves millions and millions of people from starvation, you would be set for life anyways.  You could make a fortune on speaking tours.
Wayne, when do you plan on delivering the goods?  When will we get to see definitive proof from independent third party testers that what you claim is true?  When will you give a demo of your system, something like the system running for a full month driving a generator that powers two kilowatts worth of oven heating elements inside a protective metal cage.  We want to see the red glow 24/7 on a webcam monitoring system.  We want to have volunteers taking shifts so they can observe the system in person and monitor the voltages across the oven heating elements and feel the heat with their hands.  Can you do something like that?
mrwayne
Thank you for the question,
We are currently being assisted by friends of Mark to set up the extended testing and degradation analysis (with the Data collection model).
We are upgrading the processor to be able to track real time  and continous Data.
We have raised our own personal "Bar" to exceed the proof beyond speculation.
At the same time, our engineers are arranging the manufacture of the next scaled up model the first Beta model, we have meetings Tuesday with the manufacture bidding for the job.
Regards to open sourcing - I have seen the notes from others here where Open sourcing - is assumed to be a way to avert supressions, and greed. We have seen no supression - beyound what was felt here and or casued by unbelief - and I am dedicated to make sure that the benifits of this machine reach the world.
I love the business model we are currently entertaining, but we have a couple more professional strategic planing presentations to review - we will see.
"Deliver the goods"
I see the question is regarding the Proof of concept - third party testing.
Some assumptions on this site are that we are here to seek approval, I came here to share the excitement, and answer questions within limits.
The third party testing is being done for the people and groups that are helping to provide the resources that will "actually make these available" - that is more important than the hope that if it was let go - any one would spend the money to try in something they do not believe in.
We will be releasing to scientific journals and presenting the Data professionally, when Marks Group reccomends.
I look forward to the longevity runs as well, Next weekend is when we have the help to set up the new plc equipment and software.
Thank You
Wayne
Wayne:
I wish you the best of luck.  Please note that when results are shared publicly that you are going get feedback from all sides.
If I can make a suggestion, you should to show the device driving a load.  Just seeing it "self running" is not enough.  Will the device have an output shaft?  Assuming it does there is no reason not to show the output shaft driving a generator that is clearly driving a big electrical load with live measurements and all wires exposed.
As an example, you could set it up on an asphalt surface, and you should clearly show that there is not an electrical outlet box embedded in the asphalt before you set up.   A setup on regular ground will not cut it.  Then just drive a big electrical load continuously for a month.
Ghost
Quote from: microcontroller on June 02, 2012, 01:19:33 AM
The only thing he is going to share is overunity excitement  ;D LOL
Place your bets please.
Our current corrupt Government will never let clean self running free energy machines be accessible to the general public of the world. Especially commercially. NEVER! Why? It will destroy the Government’s general control of the world population. Look at others who have achieved free energy and tried to make it commercial, never happened and never will as long as this corrupt Government is concerned.
I bet all the money I possess microcontroller  :)
johnny874
  @All,
This is for a watts calculator. With what I am working on, I would be generating about 6 watts of power
by using a wheel with 1/2 Nm of force. That would be 1 kg at 1/2 meter.
To generate 25 watts takes 4 kg's @ 1 meter from it's axis of rotation. And it would need to rotate @ 60 rpm.
Sorry folks but can't accept that Wayne's invention is developing that amount of power. If so, I would have
to think it would be easily demonstrated that it is a working prototype.
To Wayne, I like engineering and have worked with complex systems, one's more complex than yours. Myself,
I know a 12 volt battery could allow your system to work while causing a sufficient pressure differential to give
it the appearance of it actually working. But 25 watts requires something that would be self sustaining in an
obvious way.
@All, here's a watts calculator. .
        Jim
http://www.magtrol.com/support/motorpower_calc.html
edited to add;
@All, pressure sensors don't need plumbing. With a tree that is connected with tubing to other components
is something not needed unless air pressure is being converted into hydraulic pressure. And for this, a large
piston in the bottom or top of the bellows would be the best location. Hydraulic lines tend to be rigid as a
result of being under high pressure. But this would require only one line per bellow.
And for changing the primary air pressure for work would require only changing the area of that bellow by
using either a diaphram or an expansion chamber like the cap I mentioned. And neither is visible in the videos.
If some how Wayne's invention works (which I doubt), it is poorly engineered.
