mrwayne
Thanks Chet,
Can anyone answer - legally ...
Does "open source" mean giving up your rights of inventorship?
Such as implying you are giving it away freely?
Can you share your discovery without giving up the rights to it?
I understand it can be copied as soon as the first production model is out of my protection?
what are the limitations of this forum, in protecting an inventor, who wants to share, but not throw it away?
I am in the process of mutually signing a non disclosure for a green company in Australia, does that lose all value here?
Wayne
ramset
Buddy,
Unfortunately you need to see a lawyer,And in the long run.. The lawyer will be the Guy that makes the Money on this!
Par for the Course!
Good luck!
Chet
PS
Tell you what,There is a Guy Up in Canada "Thane Heinz",From Ottawa University
He also has a "Tidal" device ,Look him up .
Several people here have gotten Patent info /offers of help from him.
We thought he was Open Source also?
Thanks Grandma
core
Quote from: mrwayne on April 11, 2011, 08:58:18 AM
Thanks Chet,
Wayne
Since the explosion of the internet the patent protection/ inventors protection is a bit murky. If you write about your idea on a forum or web page it is considered 'Published'. If published you must wait one year prior to patenting.
Regardless, I had a family member who worked for a patent company and there is a seldom spoken process that most company's don't want you to know. It is called 'Poor man's Patent' and this is something anyone can do for cheap. Also it puts the Government on YOUR side.
The 'Poor Man's Patent' is legal in the USA I'm not sure about other countries. It goes like this.
Step 1:
Define your invention in complete detail on paper. Include print-outs of this forum and pictures. Do not be lazy here, it must be in DETAIL as it would be used in a court of law. You must prove, beyond a shadow of a doubt, that the idea is yours.
Step 2:
Place all data in a US postal office envelope, you will be mailing this to yourself. The post office will 'stamp' your envelope with a 'Date' (very important) Note: When this happens it becomes Government certified.
Step 3:
When you receive the package in the mail 'DO NOT OPEN IT....NEVER!!!!!' This is a sealed Government certified package.
The purpose If someone takes your idea, even a company, you have a SEALED document Government and TIME stamped that contains enough information to prove 'Who' is the inventor. This package must only be open in a court of law by a judge Only a judge can open the sealed document. If you tamper with it 'You lose' keep it in a safe spot until that day comes.
Above is 100% legal but not known by many.
Regards and good luck.
Core
mrwayne
You are right, I will ask my lawyer.
To date, my attorney has charged me some where over $24,000 on this one patent.
He is expensive, but at least he is honest - he originally refused to "waste my money" by patenting another "over unity device"
After he and his engineer team (NDA) studied my machine, performed the patent search and they did come to the house (demo), they insisted on being the patent lawyers - but not for free.
I pray I am the exception to the rule.
All I know for sure- it wont be the design that stops me.
Thanks and greetings.
mrwayne
OK, the real over unity device is going off line.
If and when I am sure it is safe, I will release all IP here, you all deserve to know.
Concerning the Z.E.D. it requires seven square feet of air at atmosphere (prior to compression) to complete a stroke.
The compressed PSI is of course set by the resistance to the travel, the travel stroke length is also determined by the pressure.
So my internal design converts 7cf of air into Buoyancy - that lifts equates to 4 psi = 3200 pounds and travels eleven inches, 7 psi = 5500 pounds at 8 inches.
Those are the real world numbers - and the weight of moving parts has already been subtracted.
That is not much more than a standard air cylinder - the difference is - the exhaust.
When the system is topped out -(the hydraulic system has stored the upward force), the system doe not reverse itself.
in fact the inner most chamber is forced downward when its pressure drops - by the head pressure in the layers above it.
This causes the layers to separate and continue to push down during entire exhaust.
It is like a loaded spring releasing.
We use that air to assist in the operation of the other Z.E.D
In short the Exhaust supplies over half of the power needed to raise the other side.
And then we switch directions.
Less than half of the energy captured in a single side going up is used to supply the input energy.
All of our input is performed hydraulically, and all of the energy the generator (ran by the excess) produces is free.
No compressor, no noise, and the only wear parts - besides the electrical generation - is the seals in the four hydraulic cylinders.
I have four cylinders, two larger, and two half that size, the larger captures the energy, the smaller assist in pushing the air to the other side.
pretty simple to verify. one stroke for one stroke.
I think I will leave the rest as Conrad said - Secret for the protection.
But I am willing to share with most anyone with a non disclosure.
mr.wayne@hydroenergyrevolution.com
You will see the old rule of thumbs going away, and those of you that just knew it in your hearts - are right.
