Archurians defeat Newtonians
Started by The Eskimo Quinn, April 16, 2011, 01:34:11 AM
The Eskimo Quinn
a new video has been done to replace the other two so it can be watched in one run in the right order
http://archurian.com/The_Key.html
My PROOF THAT DEMOCRACY IS DEAD AND THAT WE MUST ATTACK AND KILL THE NAZIS IS RIGHT IN FRONT OF YOU, THE U.S, aUSTRALIAN AND BRITSIH GOVERNMENTS ARE THE OPPOSITION PARTIES TO THE ORIGINAL INVADING GOVERNMENTS, DEMOCRACY DIDN'T WORK, BOTH MAINSTREAM PARTIES ARE NAZIS, DEATH TO THE NAZIS, DEATH TO ALL SYMPATHIZERS AND SUPPORTERS http://www.youtube.com/watch?v=39c-kpgDY58&feature=related
SkyWatcher123
Hi eskimo, thanks for sharing your thoughts.
would this apply to your thinking also.
A large vertical tank silo filled with water and a very heavy float at top.
This very heavy float at top has a latch mechanism so it hangs at top and a water turbine at bottom of water tank to either charge a battery or operate a water pump when valve at bottom is released to vertically pump the water into another holding tank beside the main water tank.
Now that all or most of the water is raised into the holding tank, the very heavy float connected to the top latch in main tank is released and this heavy float is attached to a pulley system to turn a generator.
When the heavy float reaches bottom of main tank, the water in holding tank is released into main tank and the very heavy float then rises back to the top to repeat the cycle.
So we acquire the excess energy from the very heavy float descending and turning a generator.
Now if the initial water draining from main tank is not enough to fill the holding tank, then part of the energy from the descending heavy float can make up the difference.
Seems that this could be a similar principle to what your describing.
peace love light
tyson
onthecuttingedge2010
Quote from: The Eskimo Quinn on April 18, 2011, 08:21:27 PM
Newton spent his entire life proving what he found to be real, are you there to prove his theories wrong? if so I will support newton. classical mechanics breaks down at the quantum , newton knew nothing of quantum mechanics.
Airstriker
Quote from: The Eskimo Quinn on April 16, 2011, 01:34:11 AM
Video uploaded email copies available
Newtonian laws of equal energy destroyed any 5 year old can test it at home, no money or equipment required.
I win
Put your archurian bullshit to your pocket and sit quite. Man this is pure basic physics you know nothing about ! When you let the apple free fall, at the bottom the Potential Energy is zero, but Kinetic Energy is not zero. Kinetic Energy at the bottom is equal Potential Energy (which the apple had at the starting point) minus Energy you spent on all the losses (air drag etc.). So in fact you don't gain energy. You loose energy on overcoming air drag.
And then starting at the bottom with your Kinetic Energy you can convert it back to Potential Energy (again loosing energy for all the drags). As this Potential Energy is less than the starting Potential Energy, the apple is getting at max 90% of the initial hight.
Can you tell me Mr super druper archurian, where Newton is wrong here ?????????!!!!!!!!! Go to primary school and learn stuff.
Sorry for being rude but I cannot stand it any more.
The Eskimo Quinn
Extract from key page
Many if not most of you wish you could make something that proves visually this is true, well you can, it will not help you though, the cost? nothing if you have a bicycle. The object is to show that the Newtonian theory of potential energy and the conservation of energy exists, we believe they have it wrong. The conservation of energy would be in line with the planet and the universe, so from the electron to the planets and everything in-between, what do we know is certain, not theory but certain? That they are all in a constant state of motion, not frozen or still waiting for some other force to make it move, So Archurian conservation of Reality is that everything has sufficient energy to continue moving or to derive movement from one to another. To show A Newtonian wrong is pointless, but we will do it 3 times. The first is to show the theory and math of potential energy is false. Take a set of scales or see saw or evenly balance lever, place 1 kilo (or any weight you have two of) now place one on one end, now when it is ready place the other on the opposing end, and the lever will rock before balancing, this rocking shows more energy than fall to lift, now because Newtonians cannot explain it, they say that is part of the potential energy. Horseshit, take one off now repeat with a one kilo bag of sugar pouring from the height you place the weight on, and it will come to balance without rocking, they will give some other horseshit story to try and explain where the rocking went, let them finish their lies, now repeat the last exercise and follow the lever down with the bag of sugar, so you change the math and potential energy, what happens, exactly the same thing with two completely different sets of math and potential energy stories.
Now we will show you 50 grams falling on the bicycle wheel and it going past twelve o’clock or more than a full rotation. Which according to Newtonians is impossible and yes we perfected the test so everyone in the world can now do it.
