Thanks to ALL for your help!!
Zero-Amp Technology
Started by ElectrifiedMonteSS, April 19, 2011, 01:45:42 PM
Pirate88179
Quote from: ElectrifiedMonteSS on May 09, 2011, 09:06:26 PM
Can the Fuji  Camera circuit be used to power a coil? What is the voltage off the cap? All the cap has on it is N0537, then right below that is PET..
I don't know what you mean by powering a coil?  all of the Fuji's I have modded had caps of 350 volt ratings.  The modified Fuji puts out about 400 volts or so.
ElectrifiedMonteSS
Bill,
Sorry for the confusion..  I have too many ideas running in my head at one time! LOL
Let me kinda explain.. I know the cap in the camera circuit drives the flash.. If I were to remove the flash and input the ends of a electromagnet coil.. Could the cap energize the electromagnet coil?
Please excuse my ignorance in dealing with circuits and the like.. I'm in the crawling phase right now.
Thx,
Kevin
Pirate88179
Quote from: ElectrifiedMonteSS on May 10, 2011, 12:13:43 AM
Bill,
Thx,
Kevin
No problems.  I am not sure of the answer to your question.  My guess is that to energize a coil you would need dc output and the Fuji outputs pulsed dc from the modified version.  If you too it off of the cap, that should be dc but, that cap will empty in like 1/10 of a second and then need some time to charge up so, it would not energize your coil in anything near a continuous way.
I hope this helps...I too am still learning all of the time.
ElectrifiedMonteSS
yeah it helps..
The electromagnet coil I’m working on will not be run constantly.. It will just pick up an item then drop it. But I want to do it in a repeatable fashion.
I know there are a few camera circuit projects that were talked about in this thread I started, but most were based of the JT project..  I additionally need to incorporate a hall effects switch which can be used as a timing device.
Still learning this electrical stuff day-by-day! :o
ElectricGoose
Once you know enough about resonant circuits it is 'simple' enough to build a circuit that consumes VERY low amps and looks impressive to a newb that knows nothing about electronics.  However, what are the volts going in?  With a few inductors and a well placed tank, you can have that high voltage pinging around to make up the amps on the back end.
It all adds up though WITH LOSSES except in a couple of circumstances where the zero point applies.
I have never seen this bozo and his zero amp setup in the flesh and I dont need to because the EVIDENCE is overwhelming.  He states he has HUGE overunity (by way of amps) but never states watts.  IF he had such a huge amount of OU, he wouldnt require a generator (which his his source of High Volts) on the front end or that big battery bank
Additionally, he has been caught out in numerous lies ("I was a navy seal blah blah").  He didnt even finish basic training!  Anyone see a pattern here with these guys and their delusions of grandeur?
Yet another Charlatan like Steven Mark.
These guys should be exposed by the OU community itself to prevent embarassment.
