Thanks to ALL for your help!!
Free energy from zinc.
Started by stevensrd1, April 21, 2011, 05:58:01 PM
stevensrd1
I took a carbon zinc battery, removed everything in the battery and kept the zinc can. The can was washed, boiled and dried. NO remains of the acid or carbon or tar or anything left in the can. Just a clean zinc battery can. Then I took 2 diodes. Soldered one diode inside the can, to its inner side. Then the other diode was soldered to the outside of the can, and by using the polarities of the diodes I had a positive in the can and a negative outside the can. Now I connected an earth ground to the positive diode. And using my meter connected to the ends of the diodes I got a constant reading on my meter on DCV 2V setting of around 200 to 300. This varied ever slightly over the time during the day and night but always around or rather between 200 and 300,,sometimes more then 300 actually. Now this is a form of free energy in itself all tho be it a very low amount of power, but its constant and non stop. I have also found I can ever so slowly recharge a capacitor with this setup, and if I connect an antenna to can itself,,the capacitor charges faster,,but still over all slow. None the less this is constant free energy from zinc. Now I have read that zinc will give off electrons if in the presence of ultra violet light. I have also read something about a metal charged sphere,,that the electrons will migrate outward on the outside of the sphere and not remain inside or on the inner side of the sphere. I really am not sure how this setup I made is working,,but it is working. I dont think its being powered by ultra violet light,,as the capacitor will charge at night in total darkness. I dont think its really working as a charged sphere with electrons just collecting on the outside of the zinc can for more surface area. And I dont think this setup is working like a crystal radio set since the diodes used are in no way like the ones used in a crystal set, they are the bigger black diodes 1n400 types. So how is it working,,all the time,,is the zinc perhaps just pulling up electrons from the earth,,or is this perhaps a primitive form of zero energy being tapped into. Questions remain, I made a video of a possible improvement to this setup,,you can view it here, please read all written there as well to better understand. http://www.youtube.com/watch?v=AsZgyI9WsFE
Tito L. Oracion
Another good experiment steve  ;)
FatBird
What is the Length & Width of the Zinc Strips?
Thank you.
FatBird
What is the Width & Length of the Zinc Strips?
Thank you.
stevensrd1
The schematic shown was just a concept,,I have not tried it, but was thinking since I could charge a capacitor with the zinc can, perhaps there was other ways to get more power from it. If your interested in something I found a bit neat, check out this link,,its where I power a joule thief with a plasma ball. http://www.youtube.com/watch?v=uA36b_nzgDs
