Build a Moray-like device
Started by Ros-Co., May 28, 2006, 06:09:32 AM
hartiberlin
Ros-Co,
Morray just did build these negative resistance valves with
radioactive material doped diodes.
This then worked in LC tank circuits as "passive" amplifiers and
with several stages he got about 1 to 3 KWatts of power
in his biggest units.
The power came from radioactive material decay and was converted
directly to electricity in RF bursts to power and amplify the radiowaves
in the LC tanks.
The antenna he needed was only to energize his first
LC tank via radiowaves from a local radio transmitter so setup
the oscillations in the first  LC tank , the valves did the conversion of radioactive
energy to electrical energy in his uran doped diodes-valves.
This was the only secret of Morray.
The first doped diode ( negative resistance)
was his Swedish stone he found in a swedish mine
when he was there on vacations.
It was also radioactive and worked as a nice
"passive amplifier" for radiowaves, when he tried this
as an diode in his earlier radio receiver experiments.
When he draw too much power from them, these stones
overheated and  burned up.
Later, when he got enough power out, he could have probably
started his device via a small battery to power an RF oscillator
and feed back some power from the huge output back to the
input again, but he still used an antenna to start the oscillations.
This is why it was a mystery to many people, if he drew the power out of the atmosphere,
but he was just using a local radio station to start the oscillations in his first LC tank circuit,
but the output power came from forced excited radioactive decay, that happens, when
you energize these doped diodes with electrical RF waves.
So it is probably not too difficult to build a Morray device,
if you havethe right radioactive doped  diodes.
Regards, Stefan.
kokomoj0
i have been digging around a bit on this device.  do you have any good links to follow on how to create or obtain these diodes or even more info on the device itself?
Ros-Co.
example:
http://www.angelfire.com/electronic2/energy0/adamsky_energy_circuit.html
http://forums.hypography.com/science-projects-homework/4905-ion-valve.html
http://www.linux-host.org/energy/energydevice.htm
http://antigravitypower.tripod.com/FreeEnergy/p.brown.html
Based on the last experiments, i think, the Moray tube maybe very similar to resonant nuclear battery...
The antenna only just produce a very little power, but it helps to start the "self sustaining" effect in the circuit, and it becomes self-runner.
The other parts of the circuit are similar to an inverter, but semiconcuctors are not preferrable, because it works on very high voltage.
But with modern IGBT, maybe it's a solvable problem
Prophmaji
my family used to sell CB's or Citizen's Band two way radios.
When electrica storms used to occur, we would disconnect the antennas from the radios.
When the lighting would strike,the antenna ends would fire a spark from the tip to the ground on the antenna lead.
When this happened, the cable would both twist and move in a specific direction..of course. The combination of all three is very, very, very, very telling, when it comes to vortex work. Or understanding the base nature of a 'interference' of two waves creating a resultant vector that 'infringes' upon our dimensional vector, thus creating atomic structures at the nexal point of the waves..thus describing reality and all the issues we have in understanding it. The atomic or vibratory quanta interference meeting point of the fields and the resultant vectoral equvalent is the essence of atomic structure. Thus the vortex action. Thus the fact that heat can be substituted for time in formulas that are true to the real nature of the universe. The wavefrom's meeting point describes the two reflections of energy off two 'surfaces' Inside and outside. Nucleus and electron shell. All simple hamonics from the angular components that describe the vortexural meeting point of the planar 2-d waves. Of course, once again, the overall vectoral resultant describing the given atomic structure, as it protrudes in this 'dimension', that we like to call 'reality'.
This simple point tells one, flat out, that frequential resonant energy manipulation is the key to opening all doors in energy manipulation.
it's not the only key, it is merely the easiest, and most prevelant and prolific, in terms of effective results.
A simple point that illustrates this. Silicon, or glass, when solid, is an excellent insulator and excellent dielectric. As a heated liquid, it is an excellent....conductor. This is true for most materials, when fluid.
Prophmaji
Taken from another thread, where I was trying to slip it into print....as this particualr point, when posted on another forum, earned me a visit in less than 24 hours. this sucker can probably go atomic. Design for a nice meltdown instead.
And to cross correlate for the fun of it, this is the mechanical equivalent of what you need to manipulate in energy manipulation of crystalline lattice structures. Basically a polarized hysteresis point. resonance, it is.
This is the key point in moray's capacitors which were excited via using Americum, polonium, etc. (like blowing across the top of a coke bottle) RF resonance of ground crystal based capacitors. He ground his capacitor dielectric out of a single pure crystal, and to a uniform size. He created a RF resonant polarized hysteretic helmholtz resonator out of pure powdered crystal dielectric, and the right shape, and charge levels.
Newer plastics have just been 'figured out' that have high levels of polarization, which will allow them to store over 7 times the energy of typical cutting edge 'current design' capacitors.
Moray managed to get one heck of alot more out of the polarization allowed by pure matched crystal powder. And the crystal is inherently resonant. In multiple ways.
