Build a Moray-like device
Started by Ros-Co., May 28, 2006, 06:09:32 AM
mikestocks2006
Quote from: Ros-Co. on June 07, 2006, 10:31:00 AM
Hi!
My antenna doesn't charge without any artifical source.  I can't capture any ambient electric energy.
Is it necessary for work?
I heard about that the device works indoor too, because the antenna captures radiant energy. (If you pumped it with special impulses, and special frequency)  Is it correct?   Moray's second generation device is not use antenna.
I'll try the electret trick.  I read your idea with oil heating of the cable.  My flyback driver easily charge the cable up to 25KV.
Ros-Co.
Hi Ros-Co,
Are you trying to duplicate this ? :
http://www.nuenergy.org/alt/radiant_energy_diatribe.htm
Please post the results if any, as it fairly simple to implement (if one has enough space to stretch the cable), and it appears very interesting.
TIA
Ros-Co.
Yes, I tried to duplicate it, but antenna doesn't produce any charge.  Unfortunately I haven't got enough space to stretch it.
A device only use the atmospheric charge?  It's not exactly over-unity....     I think radiant energy should be received as RF energy. Isn't it?
Ros-Co.
mikestocks2006
Quote from: Ros-Co. on June 07, 2006, 12:54:02 PM
Ros-Co.
Yes could be.
My thoughts on the way it works and I could be wrong but something to consider:
The center wire feeds the spark gap circuit. Using atmospheric charge.
The radiant energy is captured by the outer aluminum shield (or grid depending in the cable used), when the spark fires.
So the real output "higher power" should be coming from the outer shield? Maybe it's as simple as that?
What do you think?
Ros-Co.
Yes maybe.   (Bruce maybe tell the secret :) )
So, If I understand it correctly, the outer shield capture the radiant energy.  The insulator of the coax must be conditioned for increase the electret effect.
When the spark firing, I think it generates a wide spectrum of RF energy, include the "master" frequency  (what the correct name of the universe freq?  I heard it is about 1,9 or 2,8 MHz? Is it correct?)
Picking of the master freq, incrase the energy in the antenna, and you can utilize it.
It's my idea, but I think It's not work in this simple way.  More parameter tuning reqiured.
I read your message, thanx.
mikestocks2006
Yes not all is clear. Either way if we get energy out of it without any energy input from the user, then it is a nice system. Even if the energy is coming purely from the atmoshperic electrostatic charges/fields sweeping across the wire building a static chrage to be discahrged when it becomes high enough to overcome the gap.
I wonder if Bruce or anyone else has had it working for extended periods of time with consistent positive results.
