W.K.Coombs Open discussion thread
Started by ramset, April 25, 2011, 05:32:07 PM
ramset
Mr. Coombs
Words just can't do this Justice!!
ChetKremens@gmail.com
PS
I'll be inviting some guests ,as well as opening up some threads at other forums where people have a hard time posting here!
I'll post those links here as well!
Protech
Quote:
iT'S GOING TO BE A RIDE
Ok where do we start.... I know as a kid .... now I think everybody in the world has spun a string with a weight on the end.... remember.
You would make a twirling motion to get it started then you would just move it back and forth and it would still spin, You would feel a tug at end of each movement on the shift back and forth, ?
centrifugal force correct ? But it keep spinning .........now we are going to apply that part in conjunction with gravity
Ah! gravity the force that wants whatever is not already backed up to a solid and wants to get there ...
Ah! now we take a pendulum  natures perfect way to have weight climb.....
from a gravity drop point ....But we all know that it diminishes on each swing RIGHT....they all say friction is the problem very few say centrifugal force ,,, remember that tug at the end of the string shift ?
3 things to work with
centrifugal force
gravity
motion
ok so lets add leverage to the equation  ah we all know based on a fulcrum point the weight offset....  if we have a lever at 1 inch to the fulcrum and a lever length of 20 inches ...it just might lift a beer bottle lol......
NOW add TIMING ...to the equation  ( oh very important )
OK so here is a list of materials you are going to need..
a base 2x4 will do maybe 12 inches long
a riser to attach a pendulum too
a pendulum
a weight attached to the pendulum
a way of limiting the movement of the base ( see dia )
a couple rollers for under the base
NOW LOOK AT THE DIAGRAM CAN YOU COME UP WITH THESE ITEMS
Thanks Grandma
protech
Bruce_TPU
Hi Bill,
I'm very proud for you, and of you.  Your initial posts certainly have our attention.  Also, you should know, that we can assist you in also applying for the overunity prize here on this forum, I think it is up to like $20,000 by now or so.  Stefan would know the exact amount.  There are rules etc. but we can pitch in and help you with that down the road.
I was hoping to win it with my team and I, with the TPU,....LOL  But that is quite alright!
Looking forward to learning.
Cheers,
Bruce
protech
Thanks guy guess you know where my heart is, Im not after the prize
maw2432
Bill,  leverage sounds like the key from all that I have ever seen.  Please keep up the info.
Hope to see a video of your working machine soon????
