W.K.Coombs Open discussion thread
Started by ramset, April 25, 2011, 05:32:07 PM
Bruce_TPU
Quote from: DreamThinkBuild on April 25, 2011, 09:29:15 PM
Hi Protech,
I whipped up a Lego prototype of your idea but do not see any OU effects. I tried a bunch of different configurations before I put the magnet bumpers in to add a little bit more oscillation to the system and wheels. The rollers would make the platform twist as the weight fell and shoot off at a angle of the rollers. You'd need a way to keep it from twisting so I just put it on a track.
Do you have a working model with correct dimensions and weight of pendulum? If I know the weight and scale of your model I can try to get it more accurate. Thank you for sharing your idea, I'll tinker with it some more.
Where pray tell, is your 20" LEVER, located 1 inch above the fulcrum?  please re read the directions.  Other than that, looks nice!   ;)
Cheers,
Bruce
EDIT:
Above the fulcrum is assumed.  Is that correct Bill?
DreamThinkBuild
Hi Bruce,
Jumping gigawatts 20" lever  :o , was looking at image and didn't catch that. Thanks.
Sorry Protech, I will rebuild.
Back to lab.
protech
Hi Protech,
Guy you are so off base makes me wonder.........
protech
did I just create stupid ?????????????????? man how hard is this ............ I just put over unity in your hands and this is the results ..........
Bruce_TPU
Quote from: protech on April 25, 2011, 10:02:01 PM
Hi Bill,
I have learned over the years, that stick drawing visuals do much better than words...LOL
The project I am working on was the same, most don't listen well.  It is just the human condition I suppose.
But most are certainly willing to learn.  It is always funny when someone says they have replicated anothers work, even with pictures and diagrams to follow, and it looks nothing like the original, and then they moan because it doesn't work.  Sad, but entertaining, in a twisted kind of way!   LOL
Cheers,
Bruce
EDIT:
Dream think build,
I do not recall the man saying anything about magnets!  He said to put something at the ends to control the movement.  Get it working first before modifying.
and Bill, if I am wrong about the magnets, please let me know!  Thanks!
