W.K.Coombs Open discussion thread
Started by ramset, April 25, 2011, 05:32:07 PM
Bruce_TPU
Quote from: nightlife on April 29, 2011, 11:30:16 PM
I am sorry but I have to stop playing with this becuase something else just caught my attention. Check it out.
http://www.youtube.com/watch?v=Cughym4y7Ow
Hi nightlife,
The title is "APRIL FOOLS" spelled backwards!  You may want to come back to this, please.
Cheers,
Bruce
nightlife
Quote from: Bruce_TPU on April 29, 2011, 11:49:16 PM
Hi nightlife,
Cheers,
Bruce
LOL, I just caught that.
gauschor
Uhm, what has this video to do with the current topic  ???
@Airstriker: can you please show a screenshot of the setup you made in wm2d,the one which runs forever? Mostly simulators contain programming flaws if they act like a PM, but this time maybe not... who knows
shimondoodkin
maybe it could work with controlling the magnetic flux of side magnets.
and getting gain from gravity
Airstriker
Quote from: gauschor on April 30, 2011, 04:34:53 AM
Screenshot unfortunatelly not - got memory issues on my computer when running this simulation (not because of the simulation but many other stuff runinng at the same time) and couldn't do a screenshot. Anyway I will rebuild it, make movie, pictures and working model if I don't see anything wrong with it (and I actually don't, as it's simple as... well I don't know, but it's simple ;).
So protech - who's first ? :P
