W.K.Coombs Open discussion thread
Started by ramset, April 25, 2011, 05:32:07 PM
ramset
So,
Bill Coombs You ever gonna take the steering wheel here Bud?
You didn't do this for Mullah or fame?
Definately not trying to win any Popularity Contests!!
How's about the Kids? The ones that Shiver themselves to sleep in fear?
Things can Get real Busy Real Fast in our world!
Seems like Where running around with matches and this world is one big powder keg!
OIL, Guns And Pills!
Lets Change the world Bill,
Grab the F'n Wheel,
You Drivin??,You said "We going for a ride"
Chet
Thanks Grandma
Dr
Chet : I am very much afraid that we as earthlings have just about reached that proverbial point of no return. Many people still think that its green house gasses that will do us in. But I beg to differ!!!
nightlife
 Sorry guys but I have had no luck. Anyone else having any luck? I am having a hard time with the pivit at the end of the lever.
Bruce_TPU
Quote from: nightlife on May 05, 2011, 10:53:46 PM
Hi nightlife,
Please try the pivot below, in it's proper place and see if it works.  Thanks!  I think everone is over complicating this machine.
Below, one pivot, can go left or right, and allows the lever to go up and down.  The fulcrum is the center of gravity on the lever with the pendelum and weight, to the upright.  Go 1 inch from this (try both forwards an inch and if no go, try backwards and inch, and this is where the lever is installed on the pivot.  The pivot is installed in the upright.
Cheers,
Bruce
EDIT:
1 inch in FRONT of the fulcrum (levers center of gravity)
maw2432
@ Nightlife
Sorry but I do not see how the pivot point both goes up and down as well as to left and right in your drawing... can you help a bit more?
Balance is crucial.... as seen below...enjoy
http://www.youtube.com/watch_popup?v=jJrzIdDUfT4&vq=medium
