W.K.Coombs Open discussion thread
Started by ramset, April 25, 2011, 05:32:07 PM
protech
Quote from: ramset on April 27, 2011, 10:18:26 PM
Thats my job!!
Be nice!!
Chet
lol do I need to be here ?????? how in th fk do people who have no idea tell you it does not work .....go figure
nightlife
Quote from: Bruce_TPU on April 27, 2011, 10:11:02 PM
Please read what the man wrote in his other thread.
Cheers,
Bruce
a base 2x4 will do maybe 12 inches long
a riser to attach a pendulum too
a pendulum
a weight attached to the pendulum
a way of limiting the movement of the base ( see dia )
a couple rollers for under the base
How is this any different then what I have shown? Come on people, wake up already.
Bruce_TPU
Quote from: nightlife on April 27, 2011, 10:26:43 PM
a pendulum
Sigh...  please read ALL of Bills posts from his other thread.
Cheers,
Bruce
protech
a pendulum
like realty how do you teach a idiot?
here is a guy who in his best day was a nothing ...and he wants you  to believe in him ....well its a free world
nightlife
Quote from: Bruce_TPU on April 27, 2011, 10:49:01 PM
Cheers,
Bruce
I used magnets in my drawing which I have not been able to test but I have tested the design with stops. I find that the swinging action last longest when the stops are placed close to the wheels with about a sewing needles distance between the stops and the wheels. Timing is critical as he stated but even with the most precise timing, the resistance still can not be overcome and the swinging action adventually stops. If there was no restriction, it would mostlikely swing forever but still would not provide energy. You must provide a resistance to a movement to get a energy and any resistance added to this concept will adventually stop the motion. The more resistance added, the sooner the motion will stop.
