W.K.Coombs Open discussion thread
Started by ramset, April 25, 2011, 05:32:07 PM
nightlife
Quote from: protech on April 27, 2011, 11:19:47 PM
like realty how do you teach a idiot?
here is a guy who in his best day was a nothing ...and he wants you  to believe in him ....well its a free world
I am fed up with your insults and personal attacks. I have not insulted you nor have I peronally attacked you. You have no reason to act as you are. I have provided justifyable reasoning as to why this concept will not work. I even went one further and tested it for myself so I could explain what happens as I did. Don't think you are safe and can attack people becuase you dont think they can find out who you are and or where you live becuase they can if they really want to.
Now lets try and start over and keep it civil from here on out.
MrMag
Until he shows a working model, which I doubt that he has, I wouldn't waste my time with this child. He says that he is retired, I don't think so. A grown man would never talk that way to and about others.
It's just IST back with a new name.
gauschor
The style of writing (...blah.dotdotdot.insult.dotdotdot.spelling error) really looks like IST. Might be a coincidence... probably.
Back to topic: regarding the Lego build I think we need more flywheel mass and larger dimensions for an effect. Also I agree with what Bruce said, I think we missed something with the mentioned leverage, however I am not clear how to implement it in a way that helps the device.
Quoteok so lets add leverage to the equation  ah we all know based on a fulcrum point the weight offset....  if we have a lever at 1 inch to the fulcrum and a lever length of 20 inches ...it just might lift a beer bottle lol......
Bruce_TPU
Quote from: gauschor on April 28, 2011, 05:50:06 AM
Hi gauchor,
Please try adding the lever 1 inch in front of the fulcrum attached to the pendulum.
Cheers,
Bruce
SkyWatcher123
Hi folks, well there is one interesting thing about a pendulum that uses a string and is on wheels. That is that when the pendulum weight impacts the structure, it moves forward, whereas normally if the pendulum arm were rigid, there would be no movement at all of the pendulum structure on wheels.
So it could be used to propel a car or some other purpose.
peace love light
