Alternate Fuel for Diesel and Gasoline Engines - 100% off the Bowser
Started by ElectricGoose, May 09, 2011, 08:42:38 PM
ramset
E Goose,
Very interesting ! I appreciate the direction this takes.
In stead of me just willy nilly searching for more info to study,can you
provide any other reading material or links that would be beneficial in experimenting with this?
Thanks
Chet
Thanks Grandma
ElectricGoose
Quote from: ramset on May 16, 2011, 08:22:39 AM
E Goose,
Thanks
Chet
Chet
Sorry, I don't have anything offhand.  I have done the hard yards long ago and now only distilled my own personal notes.  What I tender to you in way of hefty hints are more than ample for you to piece it together.  You already have enough.
Physics and chemistry isnt actually that complex, it has only been made so by grey bearded old men who have spent too many years in Ivy League institutions listening to their own rhetoric and rewriting the books into lengthy equations that equate to bulldust.
One of the best questions you can ask is what Professor Julius Sumner Miller always hit his TV audience with - "WHY IS IT SO"??
You know what creates HHO = Basic electrolysis (which is inefficient)
You now look at Catatalytic proccess  = CONVERSION (HIGHER efficiency)
I have briefly touched on PLASMA (which nobody seized on) = ???
Could there be a magical conversion in a combination of all of this?  Enter the Plasma Reformer!
Try it and see.
I suggest that for the LEP (low energy pulse) you go read Aarons thread at energeticforum and use the plasma sparkplug circuit for the trial.
ramset
E Goose
Quote,
Yes I did not understand that Brief Plasma /Fuel reference?
And how the gains could happen?
Was the fuel in a manifold [tube] around the plasma?,Or visa versa ?
Or in direct contact some how :o?
Things to ponder and understand if we are truly going to get away from the "bowser"!
Thanks for all your help and your patience !
Chet
Studying................
Thanks Grandma
evolvingape
Hi Everyone,
It is now time to tell you about this...
I originally designed this concept years ago before the HELT but at that point I had not even thought of the LFV and so it was shelved in pursuit of other directions.
Those directions eventually led me to the LFV, which have since led to the GECV courtesy of Mr Goose's excellent input.
The Housingless Rocket Turbine is a ring with mini rocket engines mounted on them that then drive the ring through pulsed combustion. You can consider it the same as a tethered rocket engine spinning in a circle.
Now that we know about catalytic cracking and can use a device to do it that does not require additional hardware such as pumps this idea is now viable again. It was originally designed for HHO but I have adapted it because HHO is just too hard to implement at present time.
This design releases the constraints of limited potential difference from the pivot as the support ring can be built light and strong with modern carbon fibre composites and carries no heat. This creates a much larger turning moment torque than with traditional turbine designs.
The mini rockets contain their own power supply and fuel and pump via capillary action. They are then pulse detonated with an ECV variant.
The Rocket Ring will work on its own but can be enhanced with a secondary Impulse Ring that the Rocket ring pushes against, instead of air.
The Impulse ring has an intake and a vent and inside is baffled following RotoMax concepts for conversion of energy to impulse and then back to velocity.
The rings spin in opposite directions to each other.
The load on both rings is controlled via the PMA's independently.
Enjoy :)
RM :)
ramset
RM
Who doesn't love Rockets?,What kind of efficiency can we expect?
I know you can make this work!
Talk about Simple!!,Power to weight must be rediculous!!
Plasma drive rocket motor !!
Why Not??
More Please..................
Chet
Thanks Grandma
