Overbalancing wheel
Started by SPANG, May 10, 2011, 12:46:30 AM
SPANG
Unortunately, I've come to the conclusion, that very few (if ANY) are interested in my design.
I've sent out a few designs --------- but I've yet to recieve a reply. Loads of promises -----
but as yet ----- zilch!   I wonder if anyone is to blame?  It can't be me, 'cause I'm looking for
answers!
SPANG.     (BILL.)
Low-Q
Quote from: SPANG on May 18, 2011, 11:08:00 AM
answers!
SPANG.     (BILL.)
The conclusion is pretty simple when it comes to your design, or any design regarding gravity powered devices: You cannot get more potential energy from a system which rises and lowers weights in a rotary fashion versus stright vertical fashion. It is the altitude which is interesting, because gravity happens to be aligned vertically to any horizontal surface.
Vidar
SPANG
I'm affraid you have misunderstood my design completely, Vidar!
My design does NOT work on the principle that an extra weight causes the overbalancing in the first place.
The device ALREADY overbalances ------------------- I use the'movement' of the weights ------------ TO KEEP IT OVERBALANCED.  Also note please, that TWO weights are moved at the same time ----------- one
at the top, and one at the bottom! Perhaps you think the weight at the top is heavier than the weight at
the bottom ---------------- WRONG ------------- they both weigh the same!  In fact, ALL the weights,
'weigh' the same!  Sorry!
SPANG.       (BILL.)
SPANG
Thanks for your reply Jim, and GOOD LUCK on your build.
I think that there IS a 'lull' right now.
SPANG.         (BILL.)
onthecuttingedge2010
Gravity stores kinetic energy until it hits rock bottom then it equalizes with all other objects that fell to the same state, rock bottom until a gravitational argument is completely 'settled'. using gravity alone as an answer in an argument that will never be settled unless you conform to all the fundamental forces that are required to create what you want to achieve. a force is a pressure of some variant, a force can not have energy without an input(in History) to give it force.
