Muller Dynamo for experimentalists
Started by plengo, May 12, 2011, 01:04:21 AM
plengo
Quotedon't kill the scpetics :(
skeptics are good to have specially good ones. :)
Quote- you invested energy to move closer the object and to remove the object. At this point only you made all the action.
yes but if the removing of the object is aided by the magnet than the net energy is zero. All i put it is returned during the repulsion.
Quotenow try to imagine :
- i move a wire in a magnetic field
- wire will have "current" in it
- i use this current on a bit further in a motor and convert it back to mechanical motion
even when using the current later farther in the line it will still generate a counter-force that will act as resistance, Lenz law, but yes,  I got your point. Use it outside the influence of the magnetic field.
QuoteEdit: Actually if one of the magnets is pulling all the time towards a coil, and none are in "pulling back mode" = the coil circuit is broken fizically, then in theory it should try to go forward all the time. No ?
Interesting, this is more inline with my reasoning. Would be possible to accomplish that "always out" but never "in"????
I am seeing a few components in this motor that is not the obvious at first:
- the "gate" of the rotor magnet + the coil + the 2 other 90 degree magnets are actually forming the famous tri-gate that Howard Johnson created (http://www.fdp.nu/triforcegate/default.asp).
- Ed Leedskalnin perpetual motion in place
- out of balance action of the trigger.
This is one the reasons I would think that just spinning the same rotor with no trigger would not create OU.
Fausto.
Tudi
Sterling engines work almost the same way. You provide pressure, the piston moves a bit then breaks the cycle to be able to move back almost with no cost. Meantime the second piston is getting pushed.
I have no idea if it is possible to turn on / of fmagnetic properties of a material with less investment then pull force amount. Considering the magnetic field decays rapidly, the amount of movement length would be small = sensible device.
Again, electrons just help you store mechanical energy to "rotate another motor in another place". In theory you can only loose here due to the electron transfers. Maybe we need a totaly strange apraoch. Luck of a random effect observation.
nul-points
hi guys
excuse me 'chipping in' here...
i saw a thread someone's just started in the last 24hrs or so, where they're discussing the asymmetry of force needed to pull magnets apart in line with the magnets, compared with the force required to 'slide' them apart
the member is drawing diagrams of raising & lowering one magnet on a shaft & trying to move the other magnet horizontally
he believes that there is the opportunity to get power from a magnet this way
well - isn't this what we have in motor arrangements like the Muller, etc?
we 'slide' the magnet into place sideways - the force of attraction between rotor mag and the core/coil gets converted via rapid flux change into elec in the coil - and then we 'slide' the rotor mag away, and repeat with the next rotor mag
i think the motor approach is what this member's new thread is basically trying to achieve - the spinning rotor (with its inertia and any anti-cogging, which Romero added) is giving a 'mechanical advantage' - a lever, if you will - so that we can use the inherent force in the magnet whilst doing less work than that to apply that force
just my 2c
thanks
np
http://docsfreelunch.blogspot.com
futuristic
I don't really see connection to the  RomeroUK motor but experiments that you are talking about were conducted in 1998 by J.L. Naudin: http://jnaudin.free.fr/html/2magpup.htm
nul-points
Quote from: futuristic on May 14, 2011, 06:19:45 AM
this is the new thread i referenced:
   link --> http://www.overunity.com/index.php?topic=10731.msg286214#new
the connection is to any device where a magnet gets moved 'sideways' into position on the common axis line between the coil/core & the magnet
the guy in the thread, ResinRat, believes that the action of the magnet provides more work output than the work required to get the magnet into position
he's trying to picture it with shafts or rods & such
my point is that a rotor does the 'sideways' move for us - and we get benefit from inertia, and any anti-cogging arrangement of the setup
Romero's Muller Dynamo replication is just one example
if ResinRat is correct in his thinking, then the effect he's trying to achieve with 'linear' implementations may be the reason that we see excess energy available in Romero's device
hope this clarifies what i was saying earlier
np
