Fuji joule thief full instructions video and pics.
Started by Arnookie, May 12, 2011, 03:18:55 PM
engpjk
Hi Gadgetmall,
Thank you for your kind response and suggestions and congratulations on your very impressive 38-hour lighting period!
I have tried shorting out the diode and using the capacitor connections for output (and many other options) with zero response other than the red diode light coming on every time.  I bought two Fuji cameras together from the same supplier and I have just noticed that the boards are marked differently, one being A60 and the other A07.  Examining them fairly carefully, I can see no difference between the pcbs.
I have put a photograph of the top of the board at http://www.mediafire.com/?bxj459iiqg4im8w and one of the underside of the board at http://www.mediafire.com/?nu4wnnyvtwnaavg and if you wouldn't mind, would you please take a look at them as with your considerable experience working with these boards, you may be able to spot whatever mistake I must be making.  These boards are powered by a 1.5V AAA alkaline battery with the plus on the extended copper arm, which appears to be the reverse of the polarity of some of the other boards mentioned on the web.
Thanks in advance,
Patrick
gadgetmall
GIVEAWAY . Guess how many Fuji's there are in this box and i'll send you one free-shipping included ..I can mod it for you if ask .
It's the Fuji -Jellybean jar Contest !!(Box)
there is also some Kodaks in there as well but they don't count !
Must be exact number of Fuji Boards .
I have the number written down as of today and passed along to a Trustworthy friend here . and to unclutter this thread you can PM me with your answer.
9/5/12
Contest ends 9/28/12 and the winners will be announced.
Below that picture is one of the mods i do on them .
Gadgetmall
gadgetmall
Quote from: engpjk on September 05, 2012, 09:29:48 AM
Hi Gadgetmall,
Thanks in advance,
Patrick
I will show you in a little while with your pictures . This is an aaa 4th gen board .Seen them with aa same board also . 4th gen. they work good.smaller modified CFLS work real good but you can light 40 watt one too .you have to close a copper switch on bottom of this board with solder OR add wires with an on off switch if you want to put in in a case.A Strogn magnet sometimes near a FL tube helps get it lit and also Warming the cfl with a hair dryer helps also .
WARNING :discharge The Cap with a screwdriver before attempting anything !! Do not run this mod with more than 1.5 volts or you risk blowing your transistor . The Pot has a wiper and two outside legs . use wiper and one outside leg. for further tuning you can try different disk capacitors across the outside legs . also one way of the pot twisted is a direct short of the bias voltage and is wide open full blast so use that only to start a stubborn light then back it off a bit.
Note : If anyone else has a camera board they can get hi-res pictures of i can help you mod it. need front and back
. I give The author permission to include this in his DIY instructions as long as credit goes to those who contributed AND the site where you got it from .
gadget
engpjk
Hi Gadgetmall,
Thank you indeed for clarifying the modification procedure - I will work on it.  They sure believe in making everything tiny!
Patrick
gadgetmall
Quote from: engpjk on September 05, 2012, 11:01:40 AM
Hi Gadgetmall,
Patrick\
They are tiny and thank you for the clear pictures . I don't have Macro on my 8meg droid camera because it's hacked ,cloned and a different operating rom is on it .Yes i am an xcell tech also  .
this is one of the first videos i did of a fugi . it has a "kick"switch which shorts the bias resistor for a second to light a stubborn light on a low battery. purple power Neon Neon ..
http://youtu.be/iINoVWbdBpk
Gadget
