Thanks to ALL for your help!!
Another Patent Announcement
Started by brian334, May 14, 2011, 02:05:47 PM
bsibille
the patent is to go after the guy who successfully builds it...
jane34d
How fast does machine #2 spin? How far does Machine #2 fall?
Low-Q
Quote from: brian334 on May 14, 2011, 04:05:56 PM
Its all on paper only. Drawings can be viewed online at the U.S. Patent office.
I've taken a quick look at the drawings. It seems to me that there is no good reason why you should get more buoyancy energy than it takes to empty the tank/float at the bottom. When you empty a given volume you litterally lift that amount of water up to the surface. That takes as much energy as the energy you get out when the tank is floating upwards to the surface - in order to move the given volume of water down again.
Vidar
pese
7770389 and 7877995.
A empty tank submersed in a body of liquid will float to the surface, as the tank floats up it will do work. It is the goal of this machine ...
www.freepatentsonline.com/7770389.html
US Patent Publication (Source: USPTO). Publication No. US 7877995 B2 published on 01-Feb-2011. Application No. US 12/82735 filed on 14-Apr-2008 ...
http://ip.com/patent/US7877995
7877995 · Machine to convert gravity to mechanical energy, Feb. 1, 2011. 7823380 · Free floating wave energy converter,
http://www.patentgenius.com/class/60/496.html
brian334
The issue is weather or not gravity can be a energy source used to expand the tanks at the bottom.
