dimbulb
Steven Jones,
If there is more out than in then a second and third stage and so on might
show evidence of an increase of useful energy.
If I have a AA batter with a 1000 ohm resistor and led in a conventional circuit
has a predictable amount of light.
When placed side by side with the Jones oscillator,
It is either brighter or it is not.
Lately phenomena that we are experiencing may follow Randell Mills theory.
Magluvin
There is a difference in using dc for an led vs pulsing the led.
Leds can go into a higher output mode when pulsed.
Look into older laser diode tech
So comparing brightness is not a good gauge of power output when considering dc and pulsed circuitry for leds.
Some bicycle tail lights use the pulse circuitry to save on battery life and brighter output.
Mags
poynt99
Mags,
When you say "pulsed", do you mean as in pulsed but still appearing continuously lit, or do you mean ON for half a second, OFF for half a second type thing?
Magluvin
Quote from: poynt99 on February 08, 2012, 08:33:13 PM
Mags,
Hey Poynt
Considering the freq of on and off in fiber optics, I dont believe there is much output that lingers when power is disconnected from an led. I would say it is off, no light output.
I bought a laser diode back around 1979, 8th grade. When looking for circuits to drive it, no internet then, I found a simple 1 trans circuit that required 65v input(7 9v batteries. The article explained the overdrive of pulsing.
I had later experimented with leds with this idea.
I used my old Color Computer from Radshack to simply operate a relay(to adjust the freq) with adjustable  12v in.
When you shine some leds(clear lens) on paper, at certain distances, you can see a clear view of the diode chip(square ;]) and even the tiny anode lead can be seen.
I dont remember the freq of operation but it wasnt that high due to relay properties. You know.
Anyways, as I increased the voltage in closer to 12v, when watching the chip image on the paper, you could see the 4 edges of the chip go into that overdrive mode. One side would go brighter then another and then all, as the voltage was increased.
All true.  ;]   all real.  ;]
Mags
Magluvin
White leds may have some lingering output after power off, due to the phosphorous overlaid on a blue or ultraviolet led chip.
I forget the term for the amount of time phosphorous can emit light after being excited.  Oh well, gettin old. ;]
I also wonder if the phosphorous might glow even without the led chip being energized, during off cycle, by way of reverse HV from such devices as a Jt. Not sure there, but I wonder.  ;]
Mags
