0 Members and 68 Guests are viewing this topic.
synchro1
A "Sterling Motor" could be Magnocaloricly powered  in perpetuity by two disk shaped Barium Titinate Crystals, turned inside a strong PM field so that one side was cold and the side hot to drive the motor with the temperature differential.
MarkE
Quote from: synchro1 on July 18, 2014, 08:28:48 AM
Such a device would require:  An external energy source such as the sun,  a hot reservoir such as a heated area from a lens pointed at the sun, a cold reservoir for the exhaust, such as ambient.
If you are thinking that the device itself is a net energy generator, then you are mistaken.
synchro1
The power's supplied internally from the excited atomic lattice when the crystal's magnetized. The cooling along with the heating are both below and above ambient. The research team  on the new ferro-electric compound called the temperature gain "Giant"!
Positioning a bar magnet horizontally between two external field magnets, and another upright between the magnets, or in a large ring magnet,
creates a caloric differential between the two magnets. The Ferro-Electric ceramics show greater heat gain and loss from the external magnetic field. The crystals are magnetic too.
Coefficient of magneto-elasticity.
MarkE
Quote from: synchro1 on July 18, 2014, 04:58:06 PM
It is a mistake to confuse a heat pump for a free energy machine.
synchro1
This patented generator of Nicoli Zaev proves the principle that the discharge always exceeds the input power when tested from a non-linear capacitor:
The non linear capacitor has off set egg shaped condenser plates. The capacitor may produce a magnetic field that's unique to it's particular design. Woopy has several videos of him snapping up a charge in a regular capacitor.
