synchro1
Quote from: synchro1 on October 01, 2023, 11:22:34 AM
        230% OU
        Ultra-efficient LED puts out more power than is pumped in[
MIT physicists have been testing a light-emitting diode that has an electrical efficiency of more than 100 percent. You may ask, "Wouldn't that mean it breaks the first law of thermodynamics?" The answer, happily, is no.
The LED produces 69 picowatts of light using 30 picowatts of power, giving it an efficiency of 230 percent. That means it operates above "unity efficiency" -- putting it into a category normally occupied by perpetual motion machines.
However, while MIT's diode puts out more than twice as much energy in photons as it's fed in electrons, it doesn't violate the conservation of energy because it appears to draw in heat energy from its surroundings instead. When it gets more than 100 percent
electrically[/i]-efficient, it begins to cool down, stealing energy from its environment to convert into more photons.
The LED's are turned practically all the way down for the highest level of efficiency. Not much advantage for a Photonic Reactor.
Thanks to LancaIV again!
synchro1
The Overunity LED's generating pico watts of light are no good for a Photonic Reactor, but they act as a Zero Point cooling element and could generate power on the cold side of a Peltier Module. The conversion is small around 7% but backing hot photo voltaic collectors would pay extra dividends in efficiency gain by cooling the Photonic  Reactor.
synchro1,here to read about reaction time velocity,the recombination time window :
https://www.cam.ac.uk/research/news/revolutionary-solar-cells-double-as-lasers
Maximal efficiency :
http://www.novasolix.com/
https://www.eejournal.com/article/sunshine-changing-the-world/
45-90% efficiencies preview
1¢/Wp ! The production costs target !
The exciting part begins with their plans for higher-volume roll-to-roll manufacturing, however. NovaSolix intends to move to a rolled-glass base and to replace the masking steps with drum presses and etching. Using these materials and process changes, the company thinks they can get material costs down to under 1 cent per watt, significantly reduce manufacturing costs, and increase production volumes. The finished panel cost could drop to as low as 3 cents per watt – resulting in a panel that's 2x the power at 1/5 the cost of a silicon PV cell, a net 90% reduction in cost-per-watt from today's ~32 cents for silicon PV.
From photo- to phono-voltaic spectrum converter :
https://www.powershow.com/view1/8b4e9-ZDc1Z/Fellows_Research_Group_Inc_powerpoint_ppt_presentation
45% the target ,cooled up to 10Wp per sqcm = 100 KWp/sqm
( then concentrated x-sun potential radiation ) the theoretical claim
The output improvement option :
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=3&ND=3&adjacent=true&locale=en_EP&FT=D&date=19910423&CC=US&NR=5009243A&KC=A#
Notwithstanding the formidable prior art, there is no teaching which shows or renders obvious the present invention solar harness which  utilizes magnets in alternating series with solar cells to create a conductive magnetic field to simultaneously support the solar cells in a solderless fashion and to enhance the influx of energy to the solar cells to create a high voltage series of cells. Further, many of the other features of the present invention described herein are not suggested or taught in the prior art.
Inorganic to organic magnets/-film :
https://www.google.com/search?q=organic+magnets&ie=utf-8&oe=utf-8&client=firefox-b-m
https://www.google.com/search?q=carbon+magnets&ie=utf-8&oe=utf-8&client=firefox-b-m
wmbr
OCWL
synchro1
Novasolix promises 90% with nano antennas collecting 100% of the solar
Radiation.
