0 Members and 58 Guests are viewing this topic.
synchro1
A photonic reactor is feasible simply by doubling the light and halving the OU factor to 115% with the MIT. LED's and collecting with 90% effecient Novasolix nano antenna voltaic cells for an OU factor of 5%!
Photonic Reactor :
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=129&ND=3&adjacent=true&locale=en_EP&FT=D&date=19900201&CC=DE&NR=3817730A1&KC=A1#
assumption,1985-1989 comercial efficiencies
fluorescent lamp 38 lumen/Watt
solar/photovoltaic cell radiation conversion 5%
Pure nominal : 35 Watt electric light input (photons) x 5% = 1,75 VA output expected
Claim : 35 Watt electric light input and 70 VA output !
lumen and lux,technical definition ! lumen/Watt by - fixed-1 Metre distance measurement
Solar light radiation 1333 W/sqm, on Earth surface 1000 (- 1050 W) W/sqm
https://en.m.wikipedia.org/wiki/Sunlight
The solar illuminance constant (Esc), is equal to 128×103 lux. The direct normal illuminance (Edn), corrected for the attenuating effects of the atmosphere is given by:
      E   d n    =  E   e x t      e  − c m   ,   {\displaystyle E_{\rm {dn}}=E_{\rm {ext}}\,e^{-cm},} (https://wikimedia.org/api/rest_v1/media/math/render/svg/8c5285dcb4506b8cd0acf38ed1e15915faaaffaf)where c is the atmospheric extinction and m is the relative optical airmass. The atmospheric extinction brings the number of lux down to around 100,000 lux.
The total amount of energy received at ground level from the Sun at the zenith depends on the distance to the Sun and thus on the time of year. It is about 3.3% higher than average in January and 3.3% lower in July (see below). If the extraterrestrial solar radiation is 1,367 watts per square meter (the value when the Earth–Sun distance is 1 astronomical unit), then the direct sunlight at Earth's surface when the Sun is at the zenith is about 1,050 W/m2, but the total amount (direct and indirect from the atmosphere) hitting the ground is around 1,120 W/m2.[6] In terms of energy, sunlight at Earth's surface is around 52 to 55 percent infrared (above 700 nm), 42 to 43 percent visible (400 to 700 nm), and 3 to 5 percent ultraviolet (below 400 nm).[7] At the top of the atmosphere, sunlight is about 30% more intense, having about 8% ultraviolet (UV),[8] with most of the extra UV consisting of biologically damaging short-wave ultraviolet.[9]
https://kogalla.com/blogs/tech-trail/how-many-lumens-is-the-sun
sun to ' artificial sun',observation a.   lux per sqm         and         b.lumen per sqm
fluorescent lamp 38 lumen/Watt = 1330 lumen/ 35 Watt
Can by square root law distance apply 35 lumen/Watt becoming 35 lumen/35 Watt density !?
1 metre distance radiation stream  compressed to 10 centimetres compressed radiation stream to 1 centimetre ?
http://www.huevaluechroma.com/106.php
Distance/light energy ratio !
lamp/solar cell/-film distance , lamp coated solar dots physical distance ~ ≤ 1, 0,1 mm ?
1330 lumen,38x35, now 1:1 like Watt treating : 1330 Watt x 0,05( for 5%) = 66,5 W
Near the claimed input/output doubling efficiency claim !
2023 : with comercial 15,20,25 and more percentage conversion efficiency ?
Photonic Reactor,with concentrating/reflecting focus/mirror integrated ?
synchro1
        lamp/solar cell/-film distance , lamp coated [/size]solar dots physical distance ~ ≤ 1, 0,1 mm ?
Nano antenna coating applied directly to the surface of the light bulb.
A coaxial photo-(DC output)/phono(AC output)electric converter !?
Yes,phonon- .... possible,as pure IR-spectrum transformer ,therm-/phononionic !
photo(n)ionic/phono(n)ionic = thermal noise = thermal voltage
lamp lumen/Watt improvement
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=0&ND=3&adjacent=true&locale=en_EP&FT=D&date=19901120&CC=US&NR=4972094A&KC=A#
  ' ..... It comprises a plurality of submicron metal- insulator-metal tunnel junctions in metal strips deposited on glass  forming arrays of antenna diodes .....'
Is it not the same/similar thought process ?!
Here : Prof. Ikeda Naoshi iron oxide R&D research results
https://cleantechnica.com/2011/09/20/okayama-solar-absorbers-use-%E2%80%9Cgreen-ferrite%E2%80%9D-to-generate-super-cheap-electricity-from-heat/
The team's goal is to create a battery capable of generating 1KW of energy for 1/1000th of the cost of a traditional silicon solar cell, which comes out to about 1000 yen ($12 American) per GF cell.
synchro1
Lasersaber souped up his Super Joule Ringer. The pot core and 4 coil bobbin. The pot configuration provides more core material for the multi lawyer coil then Dr. Jones hi perm toroid core.
https://www.youtube.com/watch?v=tCc-5ksv8Ic
