to be or not to be
https://www.google.com/search?q=high+efficient+incandescent+bulb&ie=utf-8&oe=utf-8&client=firefox-b-m
An other M.I.T. R&D device ,2016 :
Conventional incandescent lights have a luminous efficiency of between two and three per cent. Fluorescents come in between seven and 15 per cent,
while most commercial LEDs are between 5 and 20 per cent.The team believes its new incandescents could reach values as high as 40 per cent,
but the first proof-of-concept units achieved about 6.6 per cent efficiency.
This is still three times better than the current incandescent bulbs.
Which light device in application is the most efficiently we will see !
Being open for new discoveries ,use-and afford-able !
For ' artificial solar light'-circuits here are some mysterious claims to find :
3.   to   9.
https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=&AP=&PR=&PD=&PA=Heinrich+marzahn+&IN=&CPC=&IC=
a 13 Watt cf lamp radiated by a cristal device,after 'treatment' only +- 1 Watt consuming !?
The reality is that the dots nd coating process technology is earliest in 10 years comercial to find !
Before we can experiment with ' simple comercial ware' and each light / energy source or conversion improving device :
https://patentauction.com/patent.php?nb=11044
6.    We can build a new type of infrared heater by multiplying the heat many times and with very low cost or by multiplying the heat that comes in the building from outside. We can heat the whole building with no costs.
infrared heater  as artificial solar radiator  : ' heat-electric conversion foam box '
More info about this OSMA-TECH paint-addition :
https://contactout.com/company/Adams-Painting-Inc-6815
but :
https://www.galzeranofuneralhome.com/obituary/adnan-erkol
I hope that nobody means that a solar/photo(thermo-)voltaic cell circuit does not be an improvement related
https://overunity.com/10773/physicsprof-steven-e-jones-circuit-shows-8x-overunity/
trans(res)istor circuit with Pin 10 mW and Pout 79 mW !
synchro1
A maze of mirrors and lenses that are used to focus and amplify the bulb light may indeed work.
synchro1
  "If I heard you correctly you are using about 2.5 Watts to power what appears to be the equivalent of at least 200W of usable light.' Zero power passes from the source to the load. The input power merely sustains the coil resonance. The OU factor approachs infinity.
skywatcher
Quote from: synchro1 on October 09, 2023, 10:22:34 AM
If the OU factor is so high, it should be no problem to run it without any power source. Only a small capacitor which is charged to start it, and then it should run forever. But apparently this is not working. Which means that there is no significant OU.
We see demonstrated an electro-optical conversion ,skywatcher,1/2 from the total conversion circuit/cycle,closing : the next stage is the inversion :  opto-/phono-electric conversion !
wmbr
OCWL
