0 Members and 49 Guests are viewing this topic.
Without doubt is lasersabers experiment showing us an energy efficient light radiation solution !A first success !
The driver only applyable in LED their specific condition or also useable for incandescent,fluorescent lightning devices ?
LED related :
https://patents.google.com/patent/US8059946B1/en
In patentauction.com this application was offered ,with the below written claim :
400 Watt electric consume for a 185 sqm or 2000 sqft house per hour( Cleary : FIG. 1 The thermal radiation producing  6 in this embodiment is a SteFan-Boltzman lamp.   NOT a LED !)
https://www.pasco.com/products/lab-apparatus/thermodynamics/radiation/td-8555
ApplicationsRadiation from a hot object (˜ 3,000 K)
The Stefan-Boltzmann Law (R = sT4) at high temperatures
The Inverse Square Law for thermal radiation
Alternatively : LED as heat generation device ? Ambient,water ?!
                         cited/similar  documents ! LED as radiant heat source.
With/-out lasersaber his drive ?
LED as light and heat source ?!
Even after disclose from closed surplus power cycle generating circuits efficient light and heat sources are in daily life appreciated !
Later it is to experiment to get the natural on outer house surface light source in-house by conduction
https://www.buildinggreen.com/blog/fiber-optics-daylighting
https://m.youtube.com/watch?v=1a9TYfYPg7E
and concentrated light-electric conversion !
wmbr
OCWL
synchro1
Quote from: skywatcher on October 09, 2023, 12:27:04 PM
If the OU factor is so high, it should be no problem to run it without any power source. Only a small capacitor which is charged to start it, and then it should run forever. But apparently this is not working. Which means that there is no significant OU.
Lasersaber is not collecting any power with photo voltaic cells. He should be able to return enough at 20% to run it.
synchro1
Jorge disconnects and reconnects 10 bulbs to his Bitoroid ringer and registers zero change in input. The power that illuminates the bulbs was generated from within the bulbs themselves! The source is blind to the load. We could cover a gymnasium floor with hundreds of bulbs all lighted to the same intensity with the same input.
https://www.youtube.com/watch?v=H64mWylOT_s
In german ' displacement current' is called ' Blind-Strom' ! ;)
Wattless power : an electro-magnetic source only emitting,near field : the electro-static part
or is it ,Prof. Ehrenhaft magnetic current research : magneto-static ?
https://en.m.wikipedia.org/wiki/Magnetostatics
https://en.m.wikipedia.org/wiki/Bohr_magneton
The BIT-toroid experiment shows 4 left side bulbs and 4 right side bulbs ,4 + 4 = ?
What means the flickering  https://en.m.wikipedia.org/wiki/Stroboscope , related duty cycle/duty factor !?
Pulsed magneto-static current !?
Open results,open questions !
wmbr
OCWL
p.s.:
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=0&ND=3&adjacent=true&locale=en_EP&FT=D&date=20041118&CC=WO&NR=2004100349A1&KC=A1#
1 bulb,lumen/Watt ,calori/Watt      !?
10th bulb,lumen/Watt,calori/Watt !?
20th,
30th,
1rd to 10th,1rd to 20th,1rd to 30th,1rd to ....  : total lumen/Watt ,total calori/Watt
In high frequency devices ,millli-seconds/micro-seconds/nano-seconds :
is the inrush voltage/inrush current phase active or passive input part ?
https://adlt.com.sg/%EF%BB%BFled-driver-inrush-currents/
synchro1
Lasersaber's SJR3 circuit is simply a coil and transister between the source and load. the source is blind to the load like Skycollection's Bitoroid. The LED's act like crystal radios that generate power from broadcast radiation directed throgh a conductor. The upward number of reciver bulbs is practically unlimited!
