0 Members and 31 Guests are viewing this topic.
synchro1
Lidmotor lights a bank of LED's wirelessly off radiation from his ringer towards the end of the video.
Joule Ringer close to a replication Video from Lidmotor - YouTube
synchro1
Quote from: Goat on October 14, 2023, 01:55:49 PM
@ Synchro1
I'm not sure what you say is correct, Lasersaber mentions that the joule ringer has to be tuned to the load for maximum efficiency so adding more bulbs than the max would de-tune the circuit.
See this video "Super Joule Ringer 3.0 Tips for Success" https://www.youtube.com/watch?v=vVXzGcyzu6o at around the 5 minute mark he talks about tuning the joule ringer.
Good point. The point I am trying to stress is that Lidmotor's LED's do not draw any additional current. Tuning to ring is critical.
synchro1,such statement/-s ' stress' us to find the right answer :
https://vabira.com/light-saturation-point-and-light-compensation-point/
When is voltage/tension hight ,when current hight and/or frequency and duty ...  more important/uefull for the wished application/function !?
Sincerely
OCWL
Quote from: skywatcher on October 14, 2023, 12:45:25 PM
You are right. I'm also following the developments in the last 20 years, and i did not see ANY project which had been proven to work, and could be successfully reproduced by others. The most plausible explanation is: there isn't anything which really works. There are only fakes, lies, and (self-)deception.
There are showed/shown some before/after energetic efficiency improvement solutions !
This are success steps !
' fakes,lies,and ( self-)deception '  !?
We all are re-/searcher,some by only theories comparison others by workbench experimental !
Mis-measurements often happens,by animated newbies as by decades experienced professional academicians !
1x,10x,100x input/output trial/work process  repeat and results comparison !
Simulator(FEMM) and physical reality ,theory : near/same 1:1 ,physically 1: ?  !
Digital simulator as 3d modeller are often  ' apparent 3d',real 2-2,5d'  !
Software-industry fixed error source !
Being critical :
conventional heatpump with propagated optimum C.O.P. 3 ,ambiental medium average C.O.P.2-2,5 ,
by electric drive effective electric energy ' nominal factor :1' ,by '  Primary Energy'-mix real factor : 0,4
~ circuit efficiency ≤ 1, energetic ( thermic and e-grid input ) C.O.P.  ≤ 1
To close the above low heat temperature ' net C.O.P. ≤ 1' cycle by heatelectric conversion ,
feedback cycle ,physically/technically as ' Carnot process' ,
energy= anergy+exergy ,
not as continuum process possible ,C.O.P. under 1,by standart industrial ware use/application  !
With improved system parts clearly possible !
Or as ' artificial light/heat source' and ' photo-/phono-electric converter' coupling like here analyzed  !
wmbr
OCWL
skywatcher
Quote from: lancaIV on October 15, 2023, 07:42:46 AM
Simulator(FEMM) and physical real !
Digital simulator as 3d modeller are often  ' apparent 3d',real 2-2,5d'  !Software-industry fixed error source !
Being critical :
wmbr
OCWL
I'm not talking about heat pumps, where i put electrical energy in and get heat energy out.
These are 'conventional technology' with a limited useability and i think they are not really the topic of this forum.
What i'm talking about are all the other 'magical' things like magnet motors, or other devices which output energy without any input (in the form of electricity, fuel, etc). Devices which work at any place at any time. I think you know what i mean...
