synchro1
Look at the wireless "Exciter" effect emenating from Lidmotor's Joule Ringer! The LEDs generate the power to illuminate themselves from within their crystal lattice excited by the broadcast ring frequency and there is zero rise in power consumption from the source. Skywatcher notes worthily that tuning frequency needs to match the load.
Skywatcher,formerly this site and forum had as topic ' simple machine'-re-/search !
heat pump process,beside electric drive also with alternative drive by air-/gas-/water-/wind-motor  is a simple machine process,also in reversible function :
giving to a space a temperature increase or taking = decreasing temperature from a space !
Today such as MEMS-devices,incorporateable in human body ! Pace-maker e-source !
https://www.techtarget.com/iotagenda/definition/micro-electromechanical-systems-MEMS
Why searching for really ' mystical/exotic/esoterical  devices'  when hyper-/physics,included quanta/quantum dimension,gives us solution !?
Output from ' nothing'  does not exist,there has to be an un-/detectable activity,an actio/ a motive current , which can become the medium to harvest and being converted ,24/365 !
With fixed or variable output,source its cycle ,hourly/daily/seasonal intensity dependent !
By heat pumps the ' endless/24-365 current potential' :
the ' closed' (not thermally )thermodynamic cycle medium/fluidum ,f.e. Butanol = Butan-gas as liquid,with - ( negative degree) 78°Celsius temperature
as medium in relation to outer/ambiental temperature !
The Carnot process is also for electro-magnetic devices their process valid and work efficiency determining !
20 years back,a common net-wide in/formation lab R&prototype/proof-of-concept research :
open ideas and questions,first answer and explaination trial
http://jlnlabs.online.fr/
http://jnaudin.free.fr/
f.e.:  http://jlnlabs.online.fr/hep/index.htm
         http://jnaudin.free.fr/rvproject/index.htm
to lasersabers,skycollection  and Lidmotors et al. workbench youtube-listed vids
Bulb ( incandescent,halogen,sodium,...) array as heater ,Joule ringer apply ?
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=16&ND=3&adjacent=true&locale=en_EP&FT=D&date=19821029&CC=FR&NR=2504768A2&KC=A2#
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=17&ND=3&adjacent=true&locale=en_EP&FT=D&date=19811218&CC=FR&NR=2484700A1&KC=A1#
wmbr
OCWL
skywatcher
Quote from: lancaIV on October 15, 2023, 09:42:32 AM
A heatpump doesn't give me electricity to power my devices. There is no heatpump-based device which i can carry around, and it produces a significant amount of electrical energy by extracting heat from the air. At least i'm not aware of any such device. I can use a heatpump to heat my house, but i don't have a house.
Quote from: skywatcher on October 15, 2023, 10:59:05 AM
The heat pump in reverse function we call : refrigerator ,commonly as household appliance in 80% private households in the western !
Is the refrigerator as ' reverted heat pump' not convertable to an heatelectric engine ?
https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=&AP=&PR=&PD=&PA=Jack+Dowdy+&IN=&CPC=&IC=
100 e- units compressor-motor  in ,45 e- units( not optimized proof-of-concept)  heat stream conversion gain
Yes,the refrigerator is also as heatelectric engine useable, total work C.O.P. 0,55
With optimized compressor-motor !? 50 in/45 out ,total work C.O.P. 0,95
With conventional cw or ccw generator now as ccw and cw generator !? 50 in/ 75 out ,total work C.O.P. 1,25
With work C.O.P. 1,25 the cooling heat pump function in hot zones will become surplus electric energy generating work !
Global temperature increase living space appropriate solution  !
Same process for Atmospherical Water Generator and Vertical Farming ambiental temperature conditioningimportant !
With optimized Haeberle process !?
With optimized compressor !?
With compressor-motor stand-by on/off switch !?
Industry does not offer ' optimal standart' !
Do-It-Yourself !
Sincerely
OCWL
skywatcher
Quote from: lancaIV on October 15, 2023, 11:13:52 AM
Do-It-Yourself !
Sincerely
OCWL
I can not, and i don't want to build a heat pump. It's useless for me. And BTW it's off-topic.
