hyiq
Hi All,
Yes I agree.  Thanks for your advise. I think I will wait for Dr Jones to come back and check this circuit, then work together. I have gone a bit off track and am starting to loose the focus of this replication effort.
To prove or dis prove an above unity circuit...
Hoppy, sorry for the questions, so does that mean, a "Sense Resistor" is not a good idea of measurements?
Thanks all for your help and advise!
All the best
  Chris
hyiq
Quote from: TinselKoala on June 07, 2011, 01:24:20 PM
I am willing to do "power analyses" the same way you are doing them. Let's start with my TinselKoil and see what kind of COP we get. I am also willing to do them properly and share the techniques for doing so.
Now... are you willing to do the measurements the way I suggest, just for comparison's sake? That is, use the amount of energy in a cap bank, applied over a period of time, for input energy, and use the integrated instantaneous power curve over the same time, for output energy, and compare the two, for a true COP efficiency value?
(ETA: Once we are taking proper energy measurements, we can start talking about probe placement, stray inductances and circuit layout. These are so critical that they can actually have large effects on measurements and the calculated values derived from them. Very very large.....)
Hi Tinselkoala,
Yes, A better way to do something is always a better way. I am prepared to measure this circuit your way. Like I said, always open to suggestions.
All the best
  Chris
Hoppy
Quote from: hyiq on June 07, 2011, 11:17:37 PM
Hi All,
All the best
  Chris
Chris,
A sense / shunt resistor will allow you to scope the current waveform whilst adding negligible load to the circuit. However, when dealing with complex waveforms and looking at efficiency, this is more involved and its necessary to have a good understanding of electrical principles. TK has the knowledge to guide you well on the right way to do this.
Hoppy
gyulasun
Quote from: yfree on June 07, 2011, 07:50:50 PM
@hyiq
Chris,
You should watch this video:
http://www.youtube.com/watch?v=bcftGrBEaL0&feature=player_embedded#at=25
Dear yfree,
If you understand Russian, does it turn out how long his 'free energy circuit' runs?
He charges up the input capacitor on the left side of his schematic first with the 12V battery, then the circuit runs from that (puffer) capacitor.  Because this circuit is basically a tipical blocking oscillator, with the usual spike waveforms and with very little current consumption, I believe the run time just depends on how long the initial charge lasts in the capacitor.
Of course the output of the oscillator is rectified and fed back to the puffer capacitor as an additional supply voltage, making the run time longer than without the feedback.
So I wonder how long his circuit has run for him?
I built blocking oscillators in the past and they run for about half an hour from a 4700uF puffer capacitor but once the charge was consumed from the capacitor the circuit stopped. I wonder why he calls this a free energy circuit? Maybe his circuit does not stop?
Thanks,  Gyula
jmmac
I don't know Russian but what i understood from the video was that, he first shunted the capacitor on the left then he charged the capacitor using the battery and left the circuit to run alone without battery. As he does this, he shows the waveform of the pulses on the scope so that we can see its amplitude. When the circuit starts running alone, the amplitude decreases (maybe because the capacitor on the right is charging) and then increases again and stabilizes.
If my understanding is correct and there is no trick, then this should mean the circuit is self running with at least n = 2 since capacitor charging dissipates 50% of the energy by joule effect.
This seems to be an interesting circuit to compare with. It uses a separated coil to collect the energy and with less turns than the primary coil so that the pulses have lower amplitude and greater current. This should make it easier to feedback. The 'collecting coil' also has a middle connection that allows full wave rectifying of the pulses with only 2 diodes instead of 4 which means less voltage drop (0.7V instead of 1.4V).
Regards,
Jaime
Quote from: gyulasun on June 08, 2011, 04:41:30 AM
Dear yfree,
Thanks,  Gyula
