JouleSeeker
Quote from: DrStiffler on May 29, 2011, 11:37:35 AM
Bill, long time indeed.
Well I'm not back really, in my sadistic wisdom I thought I could save ton of work for people and the Doctor as you are well aware I have over the years taken much tar/feathers and maybe I could use some of that experience to save someone else.
The health is fair for 69, some knee trouble, pulled mussel  ;D now and then and of course the eyes are not what they should be, guess looking at all those bright white LED's is not good for you. Maybe just age again.
No I have no intention of sticking around, tons of work with the new self running battery charger boards.
Thanks, Dr.  I've had my share of tar & feathers, mostly from other research, so I appreciate what you're saying.
Someone -- where are Dr Stiffler's "new self running battery charger boards"?  I'd like to learn about various methods.
Thanks Omega -- I was thinking along the same lines:
"A supercap can work if you let it discharge only up to say 90% of peak voltage and if it produces a measurable heat safely above the noise floor. Discharge from 100% to 90% can be assumed as linear."
It should be straightforward to have tiny wires going into the calorimeter -- to turn the DUT on and off.
We measure how long it takes for the supercap to go from 100% to about 90%, then simply let the DUT run that amount of time INSIDE -- and let the calorimeter do the Eout measurement.
Looking at the self-running option as well.  I agree with several of you that that is the "gold standard" for new energy.  (I agree Mk that  "OU" carries a lot of baggage and that we might do well as a community to find a new name.   "Novel EM energy"?  Anomalous energy?  Green energy?  )
Thanks again for comments.
DrStiffler
Quote from: JouleSeeker on May 29, 2011, 04:47:33 PM
QuoteSomeone -- where are Dr Stiffler's "new self running battery charger boards"?  I'd like to learn about various methods.
The layout and functionality are currently being tested, status info can be found in the comments section of my web page. The unit will be available to academics only through p.o. from institutions. Therefore upon release it appears you could secure one.
All things are possible but some are impractical.
NerzhDishual
Hi OU crowd,
Thanks to Dr. Steven E. Jones.
Should more 'official' scientists be on our side that the alleged 'energy crisis' will be over.
Actually, I'm not a scientist and I just wanted to ask a silly question:
is this set up able to measure any COP/Efficiency ?
Very Best
Nolite mittere margaritas ante porcos.
xee2
Quote from: NerzhDishual on May 29, 2011, 06:31:17 PM
Yes. See this example > http://www.youtube.com/watch?v=smOiVmKv9f8
Note that since the output is pulses, a capacitor is needed to sum the energy of the pulses. And a diode is needed to prevent capacitor discharging back through transistor when it turns on. Each pulse adds energy to the capacitor and increases its voltage until the capacitor input power and output power are equal.
If the Joule thief output is AC (not normal for a Joule thief), then a full wave rectifier should be used instead of the diode.
NerzhDishual
@Xee2
OK.
Thanks for answering.
Thanks for the vid.
I do like the assembly.
I often use this kinda 'layout' too.
Very Best
