0 Members and 63 Guests are viewing this topic.
JouleSeeker
Quote from: Freezer on June 22, 2011, 07:54:32 PM
I don't think "they" need to back-engineer anything, they already have much better stuff on the shelf. If anything, the fact that the spooks even showed up, probably means it worked, and they needed to silence the guy who figured it out.  He seemed to be compliant by giving up the motor, so I guess deadly force wasn't needed, you know..like how some people get suicided.
You may be right, Freezer. But then why does Romero feel free to develop another roto-device, NOT a "Muller device", he emphasized in his post (yesterday, IIRC).
And will "they" try to silence others who come up with a self-running device of the Muller type?  other similar type?  interesting questions.
Does anyone know this "Baratolougus" (sp?) fellow -- seems he might know more about this "mystery"...
I'm just curious, I guess.  But beyond that, I would like to see an OU device get out to empower people without being stomped-on or enriching the wealthy elitists...
sysrun
Tried another coil-style. Saw this in Teslas U.S. Patent 0,382,282.
Needs only one Transitor. Oscillates with 30-40 Khz on 4.5 Volt.
Unfortunately my equipment is not that professional. Got only  DSO NANO...
lanenal
Making the circuit self-charging is another way to reduce input. Attached is my LTSpice simulation of a simple self-charging JT circuit. Very straight to implement if you have already built the traditional one: same components, only different way to wire them. The diode in the circuit could be replaced with a LED.
lanenal
lanenal
If you only got a PNP transistor (PNP 3906, for example), the circuit below can be used. Similar modifications can be made to make it self-charging.
forest
Quote from: lanenal on June 23, 2011, 04:05:41 AM
What is the frequency on whcih transistor is opened ? Is that resonant frequency of C and L here or only part of L connected between baze and emitter ?
