JouleSeeker
Quote from: DrStiffler on June 24, 2011, 01:42:29 PM
Scale it down?
Interesting, at the beginning of your project it was about scaling it up to be useful. I would think 45-120 White LED's or 6W FL's from a few mills has greater potential than a dim LED that one must view in the dark.
Not trying to put what is going on here down, yet the folks using variations of SEC, Tesla and Slayer/Tesla are years ahead here, even doing (Power) transmission wireless. IMHO its not scale down, its scale up. So for a dim LED at a few uW what is wrong with tens to hundreds of watts with a few watts in, the CEC is still >1.
I'm impressed by this other work, and nothing wrong with what totoalas has done.
If you read back several pages, you will see that there is a contest going on here -- working on the input power side, and using the cap/time method for measuring Pinput, and trying to minimize Pinput while continuing to light an LED visibly in a lighted room (not in the dark).  In the process of this effort, it has been observed that at a critical voltage, the LED goes very dim/off -- then re-lights, with the input power consumption going down two orders of magnitude.  Thus, we are learning new things by means of this little contest.
Admittedly a small contest, and the great goal remains -- DEMONSTRATING a self-running device, or electrical Pout/Pin > 1.
I'm still very interested, as I said early on, in scaling to higher power once OU has been definitively demonstrated.
Thanks for your comment Dr. Stiffler -- and sincere best wishes on your efforts to demonstrate CEC > 1.
DrStiffler
Quote from: JouleSeeker on June 24, 2011, 01:51:02 PM
I'm still very interested, as I said early on, in scaling to higher power once OU has been demonstrated.
I'm fully aware of the 'Contest' and wonder how the thinking is going. So is it that a device that will give you OU has no energy consumption? Is it in essence just a passive energy receiver? Isn't this so called OU determined by Pin/Pout? So if you reduce a circuit to margin of error input readings have you not removed the Pin term from the equation and we now have only Pout?
I also question how measuring the heat on a load resistor has any bearing at all on the overall gain in the circuit. Unless the entire circuit was indeed passive, except at the load, there are indeed other losses and (all) of these losses must be summed in order to see the magical OU.
I have indeed demonstrated a CEC>1, using calorimetry and this has been replicated by reputable third parties and has no bearing on what I have addressed about you direction. Condescending rebuttal does not elicit any help from someone that has already walked the same path.
Good Luck Sir!
All things are possible but some are impractical.
JouleSeeker
Quote from: DrStiffler on June 24, 2011, 02:06:34 PM
Rather, OU is determined by Pout/Pin > 1; I suppose this is what you meant.  We are not reducing a circuit to "margin of error" readings -- the cap/time method is capable of some accuracy in the microwatt range.
QuoteI also question how measuring the heat on a load resistor has any bearing at all on the overall gain in the circuit. Unless the entire circuit was indeed passive, except at the load, there are indeed other losses and (all) of these losses must be summed in order to see the magical OU.
Good Luck Sir!
If the gain is sufficient, the temperature rise in a load resistor (output leg of the circuit) may suffice to demonstrate Pout/Pin >1.
  And calorimetric methods are certainly in order, carefully done -- as I've said above also, early on.
You state, "I have indeed demonstrated a CEC>1, using calorimetry " -- that's truly wonderful, are the results available that I and others might see them?
DrStiffler
Quote from: JouleSeeker on June 24, 2011, 02:13:42 PM
A Non-Disclosure and Proprietary Rights Agreement signed in part by any reputable institution is currently all that is required. Private individuals are not included as it is impossible to determine who they are and what interests they represent.
JouleSeeker
Quote from: DrStiffler on June 24, 2011, 02:20:11 PM
  Makes some sense, yes.  Does the individual at a reputable institution sign, is that sufficient, or does a representative of the institution need to sign also?
  I'm very interested in seeing that developments such as yours reach the people, as opposed to enriching the elitists/big corporations.  Is that your approach also?  or do you seek to sell to a corporation?
  To me, this is an over-riding consideration.
