0 Members and 61 Guests are viewing this topic.
neptune
@Xee . My bifilar winding was as per your diagram .
ramset
Frankly
Quote;
a coil in proximity received the signature and converted the magnetic flux into energy as if a solid magnet passed by.
However, with the present geometry, all you will get is Transient Spike conversion.
I have been trying for years to explain this simple thing to people, to no avail. Perhaps now, there are ears to hear?
Sir
Perhaps you can expound upon the proper technique [geometry et al]?
That would be very nice....................
And we're all trying to be much Nicer theses days  ;D
Welcome back!
Chet
PS
And reguarding the "Tesla Condensor" info,
as Johny Carson used to say,
"I did not Know that"
Thank you
Thanks Grandma
dimbulb
Frankly;
You need to be specific.
What homopolar motor/generator, condenser, core, information reference.
Tesla had so many. This thread has specific information that could be reproduced.
You say you tried before people slammed you. If you want to make a point
then do it with fact.
JouleSeeker
Quote from: neptune on July 04, 2011, 07:48:28 AM
Mine also.
I agree with dimbulb and Ramset, Frankly -- please be specific with references; interested in what you have to say if you will please be clear.
QuoteFrankly;
xee2
THE SIMPLISTIC VIEW OF PROBLEM:
The current flows through all loops of coil in both circuits, thus each loop of coil has the same amount of current flowing through it in both circuits. Current flows through loops in same direction in both circuits. Since magnetic field is result of current flow, it should be the same for both circuits. Obviously the simplistic view is missing something.
LESS SIMPLISTIC VIEW OF PROBLEM:
Inductance of coil is caused by the inductive coupling between the loops. The larger the inductance of the coil is, the more energy is stored in the magnetic field of the coil. The magnetic field is created while current is increasing in the coil (when power is first connected) and remains until power is removed. Normally, there is a direct relation between inductance and magnetic field strength. Changing winding configuration changes coupling between loops and thus changes inductance of coil and thus changes magnetic field strength. Steady state current through coil is set by coil resistance and is independent of inductance of coil (inductance only effects current while the current is increasing). Obviously, this view is also missing something.
