frankly
Perhaps I can ask this. What is present in a coil of material to form the B field in the first place? If energy traverses the skin of the wire, what forms the B field? Which part of the material is effected and by how much?
Before you say "the core material", think about an air core coil. Or, even a single wire with no turns.
The B field is caused by the electric component interacting with something. What is that thing and how does this work? What does it mean in regards to "magnetic potential", or in other words, amperage?
Everyone assumes that electricity is the same now as in Tesla's day. It is not.
In fact, it is made now to prevent any possibility of discovering what I am putting forth, which is why it has been so denied. Yes, I can prove that statement. No, I do not have referances, only devices from the early part of the 20'th century in which the circuit elements are different to manage the different energy signature.
There are patents done by Tesla of wiring seguences for generators, and Eric Dollard also did a few drawings of the correct method of energy generation.
But alternators, and rectified energy from these, will not furnish the required energy to establish Tesla's "Rotating magnetic field".
This field is not a motor, nor a winding cage. That is a deception designed to cover the truth.
It is a manufactured state we have now, make no mistake. The trouble is in trying to undo what has been done.
As an example which is easy to do, place two counterwound coils upon a core and energise one with AC energy from the wall. Now, correct me if I am wrong, (as I frequently am), but, a collapsing B field inductiively sends it's energy to the other coil, correct, as they are wound in opposite directions? If the same direction, the building B field would be mirrored in the other coil? So, with counterwound, one should see the opposite B field occur, or a matching polarity. This I built, and, although the second coil delivers 240 volt energy, it has no amperage compared to the input phase. So, in reversing the current, any amperage that was set up in the core, is then removed. All that is left is the reluctance energy. This is a key to understanding where the true energy lies.
Telsa, used oscillating DC and early in the 20'th century, alternators with polyphase energy were used. AC of equal but opposite potentials.
This is far different to today.
This includes batteries and also permanent magnets, (though to a lesser degree).
e2matrix
Quote from: frankly on July 03, 2011, 11:40:18 PM
Hello all. It has been a few years since I entered here but I see the whole game is still afoot, and only now, when someone shows the fact that energy from a battery, when applied to both ends of a core at once, produces a stronger magnetic field, do you begin to question whether you might have missed something really, really important.
Indeed, you have.
The answer to your present quandry lies in the core. At the core.
Tesla used, not only bifilar winds and such, he also used an entirely different energy signature.
This was derived from, first, a homopolar generator and then, from a DC generator based upon the same principles as the operation of the Homopolar.
Also, Tesla utilised condensors. NOT capacitors. They are two very different things.
A condensor can best be described as an element which absorbs and releases amperage. Lots of it. Quickly.
This allowed his devices to ring quite differently than with voltage alone, which you will get with capacitors.
What the present circuit is touching upon is energy amplification. However, without any understanding of exactly what energy is, you will never catch your tail.
I know this sounds abrasive. Coming from my perspective, I mean it. I posted some things here a while back, in another thread and was shouted down. These have been deleted I see.
Now, years later, the thoughts of the many are beginning to come to where I was then.
The "Rotating Magnetic Field" Tesla utilised was not a mechanical device. Rather, it was an area of polarisation in a core.
In doing so, a coil in proximity received the signature and converted the magnetic flux into energy as if a solid magnet passed by.
However, with the present geometry, all you will get is Transient Spike conversion.
I have been trying for years to explain this simple thing to people, to no avail. Perhaps now, there are ears to hear?
I'd also like to know more.  However in doing a Google search and looking at a half dozen pages or so (some from tech sites) they all seemed to say capacitors and condensers are the same thing.  The term condenser was said to just be old terminology for capacitor and more commonly found in automotive terminology.  So maybe you can start with some info on that.  I've got a 650 Farad 2.7 volt ultra 'capacitor' that can quickly release a whole lot of current at low voltage.  Enough to turn a wire red hot.  So is that a condenser?  There are of course a lot of types of capacitors.  Is there a particular type in current production that you would call condensers?  In doing a search on the very large electronics suppler site mouser.com for condensers I get microphone elements (condenser mikes) and only a few small value polyester film capacitors (which are called capacitors in the listing).  So I'm confused and would certainly be grateful to know this little known difference between condensers and capacitors.  All ears :)
e2matrix
frankly,  I guess I was posting while you were writing.   Having read your last post I'm even more 'all ears' :)  I guess the capacitor vs. condensor may not be that significant compared to what you just posted but if you have some info on that I'd like to know for trivia purposes at least.
e2matrix
In trying to absorb what you last posted can you elaborate on the oscillating DC Tesla was using?  Is that to say it is positive only pulses for example?
frankly
The main difference between a condensor and a capacitor is one of geometry. I am not sure how the ultra caps are oriented, but, basically, using an element in a resonating circuit to hold and bounce back, the energy, which is specifically designed to clamp resonations, is what you are doing with a capacitor today.
A condenser is either a set of series connected plates, interspaced with either a di-electric medium if negative or a conductor if positive.
A bank of these placed in a circuit was known as a battery. This term was used from it's root meaning which is of course equally applicable to armory. Any collection of like things to deliver force.
Tesla describes in one of his papers the difference between the methods of construction. An end connected, interwound plate of the condensor, seperated by the insulating ,(or conducting, as with electrolytic condensors), set into a Faraday tube, is able to resonate at the specific frequency of the load. Modern elements do not allow this.
As to the oscillating DC. The energy delivered was both positive and negative of equal force. Only with this energy will it be possible to lock onto the wheel-work of nature.
