TEKTRON
Quote from: frankly on July 04, 2011, 06:40:27 PM
The main difference between a condensor and a capacitor is one of geometry. I am not sure how the ultra caps are oriented, but, basically, using an element in a resonating circuit to hold and bounce back, the energy, which is specifically designed to clamp resonations, is what you are doing with a capacitor today.
A condenser is either a set of series connected plates, interspaced with either a di-electric medium if negative or a conductor if positive.
A bank of these placed in a circuit was known as a battery. This term was used from it's root meaning which is of course equally applicable to armory. Any collection of like things to deliver force.
Tesla describes in one of his papers the difference between the methods of construction. An end connected, interwound plate of the condensor, seperated by the insulating ,(or conducting, as with electrolytic condensors), set into a Faraday tube, is able to resonate at the specific frequency of the load. Modern elements do not allow this.
As to the oscillating DC. The energy delivered was both positive and negative of equal force. Only with this energy will it be possible to lock onto the wheel-work of nature.
http://www.doitpoms.ac.uk/tlplib/ferroelectrics/fabrication.php ? ??? ??? ???
rukiddingme
Condensers vs Capacitors:
"Condenser" still designates the rotating synchronous machine used to supply leading kvars in a power circuit (a function of which capacitors are also capable), because unlike a capacitor, the synchronous condenser cannot store energy electrostatically; it lacks the property of "capacitance." For the non-rotating device, however, capacitor is the proper term.
http://findarticles.com/p/articles/mi_qa3726/is_200506/ai_n13643083/
frankly
And, here we are. Arguing about the internet's description of condensors versus capacitors.
The original post was to ask what formed the B field within a wire? What substance within the wire becomes magnetised, for as we know, copper is non magnetic. I mentioned capacitors as another issue altogether.
Tell you what. Take some apart.
Get an old ignition coil condensor and cut open the casing. Then, do the same for a radio suppressing condensor on an alternator. Then, an electrolytic condensor, and, while you are at it, take apart a capacitor from a microwave oven, and an AC motor, and think about the description I gave earlier.
The evidence shows us the truth, no matter what the theory is.
Look into which speach Tesla gave where he describes the condensor's construction. This will tell you what I have learned. That there is a major difference. A fundamental one in fact, without which, you will never understand the purpose of asking "what is it that forms the B field in the first place"?
I have used referance pages before, to have them changed. So, it is better to simply do the research yourselves. The components are not that hard to find. Get a hack saw and start investigating.
That is what I did.
Look into old stuff. Go to junk yards and garage sales. Get something, anything old, and pull it apart to tease the truth from it, before the "recycling" movement swallows all the history, and all proof is gone.
Even better yet, make a condensor yourself and apply it to a circuit. The components are not hard to assemble. Remember, there are positive condensors, and negative condensors. There are also both, but that is a power source. We are interested in only catching and holding one side of the energisation.
No.
I am getting lost again.
Let us focus on the task at hand. The reason why B fields manifest around a wire when energised.
poynt99
Quote from: frankly on July 04, 2011, 10:40:38 PM
How is it that the movement of charge does not cause the B-field to manifest?
I ask this because I assume you assert that the standard theory does not explain it.
.99
frankly
No, I am asking what causes the B field to form, when the wire is energised by an electric field. Which specific component in the air or wire is aligned to form the magnetic flux? Why does this phenomena have reluctance,  reactance and capacitance? What FORMS it? For it to exhibit reluctance, it must be influenced by gravity, and therefore have mass. WHAT IS IT?
