JouleSeeker
Good point, Mags.
Quote from: NerzhDishual on January 08, 2012, 02:45:54 PM
Hi Prof. Jones,
Thanks for reactivating This Peter D. Davey's device.
Why did I stop working on this device?
Just because I was disappointed by my results.
And also, perhaps, because a lack of perseverance.  :-[
Anyway, I continue to believe that this device is worth to be tested with a positive mind.
Would I reconsider?Yes, of course.
I agree with your your method. I used a similar one.
I got some "COP = Coefficient Of Performance" more than 0.9.
I also measured few "COP" slightly > 1 but, IHMO, these are measurements errors.
I did not use any calorimeter.
I only considered the initial and final (tap) water temperature and the volume of the said water to calculate "what was going out" assuming that my kinda "Kill-a-watt" meter was able  to tell me "what was going in" with enough accuracy. Actually, with a mere boiler I did not get unusual results.
I use prudent "inverted commas" just because I noticed that writing some appellations immediately rose some stinging remarks. :P
Just in case, my page :
http://freenrg.info/Sonettes_Davey/calcul_sonette.htm
I did not try any "input current frequency" tuning.
I just tried different "boilers" pathetically hoping to stumble upon a good tuned one.
I mean: a boiler that resonate at an upper harmonic of 50 Hz (in Europe).
I also tried to figure out the main "self freq" or some devices (in air).
http://freenrg.info/Sonettes_Davey/Freq/
This should be useless as the "self freq" of a device is not the same in water than in air. Is it?
Tired to blow too many "main fuses", I also built a fuse box allowing only "input amps" < 15.
With this limitation I did not try to boil water but I could perform some electrolysis at the same time.
Now, I guess that I should experiment:
Inverse osmosis filtered water.
Distilled water.
If you have any suggestion, I would be pleased to experiment.
Very Best
OK!   Je suis heureux, mon ami!
Good to hear from you again, Nerzh.
  Let's say a good fellow in Serbia provides such a "sonic boiler" that begs to be tested.  (I will spare you all the details of the discussion between him and me... Proceeding very well!)
  However, it needs 50 Hz and 220-230 volts to operate.  Hence, I seek someone (or ones) to do the testing in Europe.  Should be straightforward.  Do you have a kill-a-watt meter or equivalent to measure input power from the mains?
(Shipping costs etc provided by moi -- no problem.)
Would you be willing to measure Ein and Eout (heat) and post results no matter what they turned out to be?    and we could arrange for follow-up testing especially if it turns out that COP>2 as he claims...
Further, he agrees that this will be OPEN SOURCE, so there is no secrecy or proprietary stuff to worry about!
What do you think?
NerzhDishual
Hi Prof. Steven Jones,
Thank you for your awakening  proposition !
I have an Energy Meter.
It is in not  "Kill a Watt" branded but should do the job.
I can try to measure the precision of this device with a non inductive charge
(a mere resistor).
I also can afford some new equipments and also some parts and shipping costs.
All the fees are on me.  ;D
Yes, of course, I will be very pleased to do any tests and to
measure "PIN/Ein" versus "POUT/Eout" and to post my results should they were
negative.
Open Source of course (OSOC)!
Please just give me the instructions.
Very Best
Nolite mittere margaritas ante porcos.
JouleSeeker
Quote from: NerzhDishual on January 10, 2012, 02:05:15 PM
(a mere resistor).
negative.
Very Best
Great!  The game is afoot...
OSOC!  and of course, I hope the results will be positive!  but whatever they are, as scientists, we need to report our results.  That's IMO.
And I'll pay all shipping fees (please!).
OK -- pls send your shipping address information to my private email, emdevice12@yahoo.com.
Then we'll go from there.  I'm hoping the device can be sent to you rather soon.
(Let's ask NP to join the adventure!)
NerzhDishual
OK Prof !
Sounds very good. I have just sent you a private email.
BTW: about NP/ND exchanges and strange emails...
Usually ( ??? ) a lot of our emails vanish in Hyperspace, 4Th Dimension or whatever.
Just one recent example:
NP sent me an email on 24 Dec 2011.
I procrastinated (as usual) but answered him on 01 Jan 2012 (I gave him some excuses for answering late  :P ).
Guess what? My delayed answer seems also to have disappeared...
So, Mr Nul Point(s), please feel reassured: I'm not trying to be silent and/or rude. ;D
Very Best
Rosemary Ainslie
Hello again, Steve
I'm not sure that you subscribe to my thread.  May I ask you to dip in there.  I'm in need of some discussion - obviously only if you have time.  I see you're very busy here.
Kindest,
Rosemary
