What happend to JLN? ? ?
Started by infringer, May 29, 2011, 09:09:55 PM
conradelektro
Quote from: tagor on December 29, 2012, 06:17:03 AM
voici le nouveau projet de JLN
http://jnaudin.free.fr/gegene/index.htm  et la video http://www.youtube.com/watch?feature=player_embedded&v=4W2ABWjeTrk#!
bonne année a toutes et tous
The experiment is very interesting but output measurement by help of light bulbs needs calibration in order to get reliable results.
Mr. Naudin did such a calibration when testing the Kapanadze transformer, see: http://jnaudin.free.fr/kapagen/kapagen33pio.htm
Taking the calibration data into account showed that the Kapanadze transformer (the one built by Mr. Naudin) has an efficiency of about 96% (therefore no OU).
I guess that Mr. Naudin will do this calibration for the output (light) generated by GEGENE.
Greetings, Conrad
The main difference is that this is not that high of a voltage. So DSO's can be used safely, and with this fact one can easily extract power ratings by means of multiplying current and voltage, and doing a mean over time. This method applies to ANY waveform and does away with RMS and phase angle calculation that only apply to sine waves.
tagor
Quote from: broli on December 29, 2012, 10:41:03 AM
Would be cool if this was translated to its own English thread because it seems quite interesting and very simple to replicate.
I think he will do it ( a few days is needed )
there is some french to replicate it , it is so simple
it is from a russian guy
tagor
a replication from woopy
http://www.youtube.com/watch?v=7QC-NrtHJjw&feature=youtu.be
  Publiée le 29 déc. 2012
  Hi all
Here my replication of the "GEGENE" generator, that i have found at Jean-Louis Naudin site.
This generator seems very interesting and very easy to replicate. The only special piece is the Tesla flat pancake bifilar coil as per his patent. Mine is 16 turns of bifilar soft stranded wire 0.75 mm2 standard plastic insulated.
But Jean Louis Naudin explain very well how to do and to connect .
So the first results are really interesting. For me the lamps came directly without putting a magnetic plate above the Tesla coil.
When i try to reduce the power, down to 500 watts , suddenly the lamps quit and than they come back. ???? probably due to the sensor of thje induction plate, perhaps that is a threshold between the input and output power, where the system disengage??
Anyway this is really promising, and easily measurable.
Have to buy some more Halogen an make more measurement
good luck at all
just for info i payd about 70 euros for the "Tristar " 2000 watts induction plate and some bucks for the halogen and wire.
Discussion at "Conspirovniscience forum "
Hé les gars c'est le top ce truc !!!
Good luck at all
Laurent
