New magnetic-gravity motor chasing its tail from Tom
Started by hartiberlin, June 05, 2011, 12:43:40 PM
lumen
Quote from: ramset on August 17, 2011, 05:38:30 AM
Lumen
I agree with Penno,
One question,why Brass?,We see the Magnet and Copper have a "Huge" Lenz Issue [the sphere in the copper/aluminum tube drop],Brass Not that far away from Copper!
Probably a silly point at this point ,But?
Chet
I just used brass because it is easy to get and easy to work with. If the device ran,  the brass would eventually fail from the constant flexing, but could be easily switched out for something like carbon fiber rod.
The device suffers from the same problem as another device I tried that used the Earths magnetic field. torque exists but work is "force x distance" and if the distance never changes then no work is done.
Still something there, so I will work on it for a bit and see if anything turns up.
ramset
Lumen
Perhaps a snapshot?
This device is a real tease!
Sometimes the eyes [of others]are very helpful?
Chet
Thanks Grandma
lumen
The design was originally based on the main description of the gravity device, but after the two sphere magnet concept I adapted it to test the theory.
The first pic is the cad rendering and the other two show the original configuration and the two magnet setup.
With some evaluation of the two magnet concept, I'm thinking that it may be possible that the ball joint at the top may not work smoothly under the high pressure of the large magnets and now I'm thinking of trying the flexible rod idea just to make sure.
ramset
Wow
Nice Rig!!
A hundred thank you's, Plus a couple[thank you's] from Forest too!
Chet
Thanks Grandma
forest
Man,I'm getting old. too much complicated for me. I will try with computer fan idea.Magnetic wind ole ! ;D
