New magnetic-gravity motor chasing its tail from Tom
Started by hartiberlin, June 05, 2011, 12:43:40 PM
ramset
Forest
Yes it scared me too ![can my mind put this much together at one time]
Have another look,its not as bad as you think "yet".
Its freakin beautiful [the concept]!
Like squeezing a pit [fruit] but never touching it .................
like the cat toy on the round track,that he can't catch!!
  Always in repel ...........
Thank you again Lumen!!
Tom Sphere Quotes:
Quotes:
1].Sphere magnets.  Ring magnets were to heavy and I found I did not need gravity at all.
2].Two magnets repelling each other while turning clockwise in my case.
3]. Both engine magnet and runner sphere magnets repelling each other on the same platform BUT moving together as one unit continuously  Thats where I am at now
4].You have two magnets repelling each other. The lead magnet (runner)
moves forward, the second magnet or engine magnet moves backward according to Newtons third law.
They seperate a distance then nothing happens.
5].The engine magnet CAN NOT move backward now:
THe runner magnet will still move forwad and leave the stationary engine magnet behind it  untill it reaches a distance then it stops.
6].I have made major improvements since then but the original concept is there.  Only two sphere magnets and another  inexpensive component is needed to run the device as well as simple non ferrous materials found in Lowes, Home Depot, or Mcmaster-Carr.
7, I have found I don't need the gravity
Tom
Quote:
This device starts out like a racehorse and to tell the truth I have not found a practical way to vary the speed .  To slow it down or stop it I have to place a very large ring magnet near it without the setup or ring magnet colliding with each other.
Part of the spinning platform is heavy so it does not run away with blinding speed.
Chet
Thanks Grandma
ramset
FELLAHS!!
You need to ,Must ............Have to,
Look here
http://www.energeticforum.com/renewable-energy/7982-muller-generator-replication-romerouk-42.html
Excerpt
The “transmission time” viewpoint allows us view the second assumption of Newton’s Third Law as an assumption of absolute time (or absolute simultaneity), if the action is at a distance. This assumption continues despite the reality that the “reaction” of a body to an externally applied force can not be simultaneous with the initial application (the “action”) of the external force. This profound restriction on Newton’s Law brings time into the equation -- a restriction which becomes the critical factor.
It should be noted that this concept of a non-simultaneous “reaction time” to an applied force (whatever the nature of that force is considered to be) is applicable not only in mechanics, but also in electromagnetism and other fields of physics. A sudden surge (an “action”) of current along a conductor, for example, will also result in an equal and opposite reaction -- but again not simultaneously. Likewise a rotating shaft surrounded by permanent magnets arranged so as to impel the rotation will encounter an equal and opposite magnetic force which will brake the rotation -- after a time delay, or what might be called the “Critical Action Time” (CAT)!
Holy Guacamole Boyz N girls [not sure we have any girls]
The posts of the last few days at the above site!!!
Cranky Pants Unveiled,[well that might be "scary"]
No ,its more like Now I get it
And so will you !!
Chet
PS
A discusion thread has been reignited here
http://www.overunityresearch.com/index.php?topic=827.msg16226;topicseen#msg16226
And at this Forum here
http://www.overunity.com/index.php?topic=11312.msg298257#new
WOW
Toranarod
Elias
Shadesz
And Many others............
Thanks Grandma
DreamThinkBuild
Hi Lumen,
Thank you for the pictures, that is a very nice setup. I like that flexible rod idea. I wonder how a pendulum would work in the middle? Tie the magnet to a rubber band to give it more area to pull away from the center?
All I can see when brainstorming is something has to be keeping it out of balance. One object moves which pushes another out of balance which moves the other back into/out of place and keeps going.
ramset
Tom
Your design won't leave my head!So many unique concepts
Will you be sharing more infO ?
It's like a huge brain twister!!
Thanks
Chet                              /
Thanks Grandma
Low-Q
It sure looks like it is going to run, but the force which pushes the center magnet out of vertical alignment, is counterforcing the rotation, even if it looks like that magnet is aligned to push the rotor magnet. Anyways, to me it looks like a system that is in full balance - no energy output. A short video would be nice for all of us to comfirm if it works or not.
Vidar
